586,108 active members*
3,238 visitors online*
Login Register
EMUGE-FRANKEN Forum
Open Source Controller Boards > DIY Servo controller - Page 51
Page 51 of 109 41495051525361101
Results 1,001 to 1,020 of 2171
  1. #1001
    1050
    Quote Originally Posted by kreutz View Post
    suggested parts:
    Capacitor
    Manufacturer: VISHAY DALE
    Newark Part Number: 65C0831
    Manufacturer Part No: MKP1841315404.
    Resistor (heatsink mounting necessary):
    Manufacturer: OHMITE
    Newark Part Number: 64K6878
    Manufacturer Part No: TFH85M10R0JE
    RoHS Compliance :
    Description
    Power Resistor
    Series:TFH
    Resistance:10ohm
    Thanks Kreutz.................U are an electronic genius..................
    Regards
    IRfan
  2. #1002
    30
    Uhu servo controller and spindle motor DC 220V 45A max
    Hi!
    I am starting my first CNC project - retrofitting mill Mazak V10.
    It was cheaper to buy old and heavy 8 ton Mazak instead of retrofitting my old manual mill.
    Mazak is good donor: motors, transformers, ball screws, limit switches, excellent guides, tool changer etc. - everything on place and ready to start :-)
    For XYZ everything is clear(more or less) - UHU!
    motors(Fanuc):
    X - 137V 12-16A
    Y - 137V 12-16A
    Z - 137V 30-37A
    But biggest problem at the moment is the spindle motor.
    Motor is DC 220V, 35A cont., 45A max for 30min.
    I am thinking to use UHU servo controller too but with biggest mosfets.
    And question is: may I replace IRFP260 with IRFP4232 (250V, 60A) ?
    http://www.irf.com/product-info/data...rfp4232pbf.pdf
    http://www.irf.com/product-info/data...a/irfp260n.pdf
    What else must be changed to employ IRFP4232?
    Or other solutions aviable?
    May be it is waste of time to use UHU servo controller on motor like this one?
    I really would like to read some honest comments/solutions from electrical persons about this question!
    Regards,
    Oscar
  3. #1003
    Jan 2006
    37
    Where can i buy assembled and working boards or boards and parts to assemble them. Im in the USA, in texas.
    Thxz, Mat.
  4. #1004
    30
    Quote Originally Posted by ez-cnc.com View Post
    Thxz, Mat.
    Assembled and tested
    http://www.bgmikro.com/
    Also you can look here:
    http://gsst.wikispaces.com/UHUget
    Regards,
    Oscar
  5. #1005
    Aug 2006
    2758
    Quote Originally Posted by oskars View Post
    Hi!
    Oscar
    Oscar;
    The UHU board is made to control mainly Permanent Magnet type, Brushed DC, motors with encoder (aka Brushed Servo motors). This motor is in another league, You need a different controller that provides voltage for the field coil (speed control) and armature current control (for controlling torque).
    On the other question; Both Mosfets could be employed (not mixed).
  6. #1006
    30
    Oscar;
    Thank you Kreutz!
    Your answers as always - like gold!
    But one point is not clear to me about motor.
    Why I can't just connect constant voltage 65V to armature, add encoder and control it like permanent magnet motor?
    Look at permanent magnet motor - it has constant magnetic field...
    And how you can control armature current, with voltage..?
    Ok, lets say there is no way to this motor together with UHU. Then is it possible to use regular three phase asynchronous motor ~900 rpm + 0-400hz VFD ?
    Regards,
    Oscar
  7. #1007
    Sep 2003
    552
    The controller that went with that motor varied the armature voltage up to the low RPM rating with full field amps, at that point the field voltage starts to decrease to achieve the high RPM. That is why you see 2 RPM ratings and 2 field current ratings. This is what is known as field weakening. Most of these drives also incorporate field economy, after setting idle for a minute or two the field current is reduced until needed. Keeps the motor cool.
    Darek
  8. #1008
    30
    Quote Originally Posted by HillBilly View Post
    Darek
    Darek, thanks for answer!
    You are right for 100%. Nobody 200km around here can restore that old (1979) motor controller without circuit. Even somebody will do it then connection to Mach3 will create new problems.
    Of course I can buy commercial drive for 2000-4000USD but that is not what I am looking for - low cost solution (like others in this forum).
    Please look at these possible scenarios:
    1. simple.
    UHU + independent micro controller based controller who read motor rpm and adjust armature voltage.
    2. more complicated.
    UHU + independent micro controller based controller who read motor rpm + current sensor who reads motor current
    - set voltage according to motor rpm
    - read motor current and adjust voltage. works like "field economy" as you described before.
    3. Easy, not cheap, I don't know how practical......
    3 ph. asynchronous motor + VFD
    Regards,
    Oscar
  9. #1009
    Sep 2003
    552
    If the controller is a Mitsubishi like the motor, you should be able to download the manual on the Mits site that includes the schematics.
    Darek
  10. #1010
    30
    Darek
    no, there is not available 30years old manuals :-(
  11. #1011
    May 2006
    16
    Hi all, great thread.
    Read the whole thing in the last few days! Have a question I don't think has been asked before. Some background first.
    I have recently ebay'ed some 4 brush 1200 in-oz motors with these specs:
    continuous current 7.3 amps
    peak current 75 amps
    torque constant 18 in-oz/amp
    voltage constant 13.3 V/Krpm
    I had originally planned to use Gecko's figuring the 20 amps would get me 360 in-oz peak and easily handle the continuous (130 in-oz). This should be enough for my Shoptask Tri-Power Lathe-Mill for hobby use. Being the insane DIY'er I can't resist the lure of 30 amps for 50% more peak torque and being able to build and repair it myself.
    Now the question. Unlike those who desire the UHU for it's greater than 80 Volts, does it make sense to expect to see a performance improvement from it's greater than 20 amps? In all these posts I haven't seen any use of more than 14 amps. Is the board really up to 30 amps?
    Thanks in advance for your recommendations.
  12. #1012
    Aug 2006
    2758
    Quote Originally Posted by bicycleboy View Post
    You need your motor's datasheet in order to evaluate if it makes sense investing on a higher current drive. Basically most of the sellers advertise stall torque instead of the continuous torque, both figures are important, but you dont want to work more than a few seconds above the maximum continuous torque, otherwise your motor is going to get damaged.
  13. #1013
    Mar 2007
    17
    BALDOR : Resolver or encoder
    I bought these motors blindly and now unable to understand that the transducer attached is either an encoder or a resolver.I thought it to be encoder.
    Beside the pics attached following is written on the transducer.
    BALDOR ASR Servotron (Made in Germany)
    Written on transducer:
    Type ENC DG 60 2500 imp/5volt
    Impulsgeber type DG-60/1
    Imp/U 2500
    F 150KHz
    If it is an encoder with 2500 ppr than i am afraid that i will be unable to use them with UHU.
    Any body here know about it ???????????
    Attached Thumbnails Attached Thumbnails DSC01094_resize.jpg   DSC01095_resize.jpg   DSC01103_resize.jpg   DSC01104_resize.jpg
  14. #1014
    May 2003
    109
    Quote Originally Posted by servocontroller View Post
    Imp/U 2500
    F 150KHz
    Someone smarter will come by, but it is some sort of transducer not an encoder at all. Will not work with uhu or most other servo controllers.. Might be wrong so don't take my word a gospel.
  15. #1015
    Hi ??, (Why do you never use names here...???)
    this is for sure an encoder. With 2500 cpr it's really heavy load for the UHU and will limit performance/speed. A 'good' encoder is in between 250 and 1000 cpr.
    I have no idea if the two quadrature outputs are Ua0/1 or Ua1/2. The inverted Outputs are of no use in the standard UHU layout.
    It is necessary to check if the outputs are TTL level or another signal level like 1Vpp, 11uA or a strange differential interface. An oscilloscope is needed to find out of what type the interface is.
    Over all I'd say, this motor is not ideal but might work.
    Uli
  16. #1016
    Mar 2007
    Novis
    Hi,, I´m new in this servo thing, i wold like to know how critical the value of c1 and c2 are. is it possible to replace with 22p or 33p. the supluer i use dont have the 27p.
    This cnc stuff is realy fun and i am going to explore it some more. My little experimental router is bastardly slow with stepper motors and my driver that i use is a DIY from plans "out there some where"
    Thanks / Anders
  17. #1017
    Aug 2006
    2758
    Quote Originally Posted by logarn View Post
    Thanks / Anders
    22pf will work.
  18. #1018
    Mar 2007
    Expensive!
    Thanks,, But i have to go with the kit´s. they cost a litle bit more than i have to pay for one from "my" suplyer.
    Thanks for the reply /Anders
  19. #1019
    Nov 2006
    17
    PWM frequency = 20 Khz
    According to the datasheet, the PWM frequency is 25KHz?
    Cheers,
    Allan.
  20. #1020
    Aug 2006
    2758
    Quote Originally Posted by Dibblah View Post
    Cheers,
    Allan.
    Thanks, Allan!!!
    For some reason I assumed it was 20 Khz, Thank you again. The difference is going to affect the power calculations (increase the calculated power)), but since we ended up choosing higher power resistors (for practical purposes), there is no damage done. I will keep it in mind for future calculations.
  1. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  2. Servo Controller pin out ?????
    By slowtwitch in forum Servo Motors / Drives
    Last Post: 05-28-2013, 03:55 PM
