586,094 active members*
4,025 visitors online*
Login Register
EMUGE-FRANKEN Forum
Okuma > programming with IGF
Results 1 to 3 of 3
    Jul 2007
    60
    I have a question: how do Okuma user use the possibly with the dialog programming IGF?
    Do you use it often or only on and off?
    I don’t know IGF but I have an Okuma turning machine and I am thinking about buying a machining centre from Okuma (older model). Unfortunately I don’t have any experience with IGF.
    Is it useful to use IGF?
    Many greetings
    Fertig123
    Feb 2003
    349
    Hello
    I use CNC turning from OKUMA for 25 years now but I hardly ever use IGF. I also have a machining centre from OKUMA. However I would not buy it again- either milling or turning from Okuma but not both..
    The two machine types were programmed without rhyme or reason.
    E.g. you got ”used” to the turning- you know exactly that F2 means “insert sign”... Now you go to the miller and there F2 means “delete sign” - that doesn’t fit together..
    I am very satisfied with the turning; my first LB15 is still running.
    Regards
    phx
    Feb 2008
    19
    Actually we use IGF for every program- it doesn’t make sense to me otherwise.
    Why creating all the cycle and all the other stuff when the controller can just do that for me!
    Maybe a few commands like rotation direction etc... but otherwise you can create the programs and use them immediately... works 97% of the time!!!!
