586,112 active members*
3,220 visitors online*
Login Register
EMUGE-FRANKEN Forum
Okuma > Okuma LB300YW
Results 1 to 3 of 3
    Hello everybody
    We never had a operation on the W axis on our Okuma LB300 and nobody knows how it works- so I would need your help:
    We want to program the following:
    1. turn side on the main spindle
    W-Axis should take piece
    Cut off
    W-axis drives odd
    2. Turn side on the opposed spindle.
    Thank you in advance
    Caddy
    Hello
    What controller have you got on your machine?
    What exactly do you need? -Only hand over or do you not have any experiences with the machine ( for the programming), zero point for main and other spindle, set W axis.....
    Regards
    McSti
    Good morning
    We have the OSP-P200L !
    We have done “normal” milling, turning with the Y axis before. However we always used the opposed spindle as a tailstock.
    We never needed it for anything else ( it used to be a demonstration machine,otherwise we would not bought an opposed spindle)
    Regards
    Caddy
