586,590 active members*
2,474 visitors online*
Login Register
EMUGE-FRANKEN Forum
Material Machining Solutions > Feeds and Speeds 6061
    Sep 2009
    28
    Hello Forum
    Due to obtaining conflicting information from online calculators, I approach the forum requesting feeds and speeds for profile cutting 6061 Al using a; 0.375" 4 flute rougher end mill going to a depth of
    -1.5" using a HSM milling operation. What say the forum? Thank you!
    Feb 2011
    353
    Re: Feeds and Speeds 6061
    you will need to give more information
    make and model of the machine
    control make and model
    maximum spindle speed of the machine
    does the machine have high speed machining ?
    how much look ahead does the control have
    what are the feed rates that the machine can obtain
    what kind of tool holder are you using --end mill,er collet style,ect.
    Aug 2015
    108
    If you can find a 2 or 3 flute endmill it would work better.
    I would break the depth of cut in half and do .75 at a time with HSM. 1.5" might be too much for one go at it. I usually do a 30 - 40% stepover.
    If you have good coolant to evacuate the chips I would max out the RPM and do a feedrate of about .004 to .005" per flute. If I'm using a 3 flute at 7500 RPM I usually program the feedrate around 100. ipm.
    Jun 2021
    5
    thx fot your answer
  1. Feeds and Speeds question - .125 and 6061
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 12-22-2016, 10:13 PM
  2. Speeds and Feeds for 1/8" endmill in 6061 Aluminum
    By braddo in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2014, 02:46 AM
  3. Countersink Speeds and Feeds, 6061, 6-flute carbide
    By sanddrag in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2013, 04:45 AM
  4. Feeds and Speeds help
    By gmessler in forum Material Machining Solutions
    Last Post: 02-01-2011, 08:31 PM
  5. Milling some 6061, want to move lots of metal, what feeds and speeds?
    By Loading in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2006, 07:43 AM
