Will need a solid fine tolerance 4 axis machine with a 4 jaw rotary chuck and a bed X axis of ~700mm.. Will probably need an auto tool changer / calibrator.. ~ 4 different tools/ job... Will need to be affordable at low volume runs.. ( just 1 prototype to start with)..And good at tool path optimization for a good accurate finish... Friendly and easy to work with for possible on going work... I will supply blanks.. easy to machine high density strand woven carbonized bamboo.. Files are in Rhino or DXF. Would be good if you are close to Bellingen Australia.. Couriering blanks out and jobs back will get expensive.. Heavy material. Contact Silver [email protected]
