586,102 active members*
3,194 visitors online*
Login Register
EMUGE-FRANKEN Forum
Fadal > What kind of cutting forces can a vh65 take?
Results 1 to 8 of 8
    Apr 2005
    1194
    I am wondering this because we have a pretty heavy milling job coming up and will be using a vh65. I am worried it isnt up to the task of rotating while we are cutting. Biggest cuts will be a 2 flute 3/4 endmill buried .625 deep.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Jul 2005
    100
    How far the cut is from centerline is the driving factor.
    6" dia. or less you should be fine, gear backlash should be less than .001
    at 6" dia.
    Mar 2009
    100
    Put a line M60 after indexing your A position to lock the pneumatic brake and cut away!! After your cut, hit a M61 to open the brake and index again..
    Mar 2009
    100
    Over the last two years I have cut over 100,000 steel parts on a vh65 4th axis mandrel with a modified tailstock. Largest cut with a 1/2" endmill..
    Apr 2005
    1194
    Right yes I know about the air brake we will be cutting with constant rotation. Should work out fine.
    Mar 2009
    100
    I machined a 4340 billet race engine crankshaft using the G15 YZA interpolation on a 3016 with vh65. All rough and finish cuts were nice... Stock startted out as a 165 lb 6" round stock and end product was under 35 lbs.
    Re: What kind of cutting forces can a vh65 take?
    (old thread, yes; but for future readers)
    I came across some specs for a used unit that stated 150 ft-lb (or lb-ft for the engineers in the house) of torque. I'm not sure how this compares, but this seems quite nice to me. I'd say this comes from the 90:1 gear ratio.
    Feb 2024
    Quote Originally Posted by SquareGear View Post
    This information you give will really benefit, don't worry about the fact that the topic is old.
    basketball legends
  1. cutting forces
    By dmorton in forum DIY CNC Router Table Machines
    Last Post: 07-13-2010, 04:20 AM
  2. How to calculate cutting forces
    By Swiss in forum Hard / High Speed Machining
    Last Post: 04-24-2009, 07:05 PM
  3. cutting forces
    By struthersdou in forum WoodWorking Topics
    Last Post: 10-11-2007, 12:23 AM
  4. CAM that computes cutting forces
    By teebee in forum Uncategorised CAM Discussion
    Last Post: 07-18-2006, 06:55 PM
  5. cutting forces milling
    By guido in forum MetalWork Discussion
    Last Post: 01-24-2006, 06:48 PM
