586,610 active members*
3,532 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Advice for buildinf cnc for pcb
    Apr 2015
    Hi, i want to make a cnc for pcb milling and holes. I have design this
    https://www.youtube.com/watch?v=0xQ8Z8LHbxM
    and parts i have bought are those
    Any advice or something i should avoid, do you think i wil have good result or should i change something
    My previous milling maching was Portalcyclone CNC with 3d printed parts, but now i need something better with aluminium parts
    https://www.youtube.com/watch?v=Uw2q_z3Epg4
    Nov 2012
    154
    Re: Advice for buildinf cnc for pcb
    I'm not sure the frame change will make as much of a difference as you might think. Sure, the more rigidity the better, but PCB work cutting forces are really small. Backlash matters a lot, but I don't know how much difference there is with that compared to your current nut. Spindle runout matters too, but it seems to me you plan on using a similar spindle (and faster spindle is always better). Finally, so does flatness of the table, but at the 35 micron levels we're talking about here NO hobby level CNC will ever be flat to any usable degree, so you just map the PCB on the run and compensate in software anyway. At any rate, good luck!
    Nov 2013
    4438
    I isolation route PCBs all the time, and I think your machine as pictured will do nicely.
    As blinken has already posted backlash in any of the ballscrews just will not do, they must be backlash free. Likewise spindle runout must be good to very good, 5um
    or there abouts otherwise you'l break tool tips all the time and that ruins the cut finish and accuracy.
    The hardest part is getting the PCB blank perfectly level....no matter how good the machine you'll never get it good enough, and that does not count any bow or warp in the blank,
    and every blank has some. I use Autoleveller, a software utility that probes the blank in a regular pattern and uses the height variation data to modify the Gcode slightly to follow
    the bow/warp/uneveness of the blank. I couldn't make decent PCBs without it.
    I suggest get Autoleveller, work out how it works and design your machine to take advantage of that. For instance Autoleveller can manipulate Gcode for Mach, TurboCNC, and LinuxCNC,
    and that would suggest you use one of those controllers.
    Craig
    Apr 2015
    thank you guys, i am in progress now, i will take into consideration backlash and pcb flatness and i will post news in a few days
  1. Replies: 7
    Last Post: 12-09-2017, 01:08 PM
  2. PCB mill advice needed
    By macross in forum PCB milling
    Last Post: 03-26-2013, 04:08 PM
  3. Need advice for buying CNC router for PCB prototyping
    By lindquist in forum Want To Buy...Need help!
    Last Post: 07-30-2011, 10:34 AM
  4. Need advice on PCB CNC mill
    By DrTom in forum Engraving Machines
    Last Post: 04-17-2008, 03:16 AM
  5. PCB Router advice.
    By EvilBarry in forum Engraving Machines
    Last Post: 02-15-2008, 04:21 PM
