588,366 active members*
7,410 visitors online*
Login Register
EZCAM Forum
Vertical Mill, Lathe Project Log > BT30 spindle built from scratch, with ATC possibility.
Page 1 of 3 123
Results 1 to 20 of 44
    Mar 2013
    20
    Okay, first off, I've been building this spindle for a few months already, but only got a buildlog on a Swedish forum, then I thought wny not share this build with you guys too!
    For you who wounder, I work as a tool maker for mold injection, that's why I have access to all the machines.
    Oh yeah, almost forgot, I'm making this spindle because milling spindles really fascinate me. I have a small chinese bench-top mill that I re-built to 99% and made a new BT30 spindle for (that was ~1½ year ago.) But the design and my job wasn't that great. (Because I didn't have enough knowledge and not access to good enough machines) But with the first spindle I learned a lot, so now move on to the next one!
    Let's start with a section view of the spindle design. I might make some minor changes to the design through out the build tho.
    Attachment 244004
    Manufacturing time!
    When the spindle is done, I need to measure the run-out of the tool taper somehow. So I started making a "test bar". I used Uddeholm Stavax for the test bar because it is a rust-resistant tool steel which can be tempered.
    I lathed the shaft to nominal diameter + ~0.4mm, which will later be removed with the cylindrical grinder. Then I turned the part around and lathed the tool taper, bored and tapped the hole for the draw-bar.
    Attachment 244006
    Attachment 244008
    Then I started making the rings which will offset the angular-contact bearings(for added stiffness) and also the rings to adjust the pre-load in the back roller-bearing(the bearing have a tapered seat on the axis, so the harder I tighten it on the bearing seat the less clearance it will have, or in my case, preload.)
    The rings are made of Uddeholm Orvar Supreme(2242), it is a good "all-round" tool steel.
    Attachment 244010
    Attachment 244012
    Latheing a small part for the gripper.
    I made this out of Orvar, too.
    Attachment 244014
    Now, let's get serious and start making the spindle shaft!
    For the previous small parts I used the smaller lathe, now for the shaft i used the heavy-duty one! I actually like the smaller one better, but for this job the bigger one is better suited.
    This, too is made of Orvar, quite a big chunk of tool steel!
    Attachment 244016
    Attachment 244018
    Some hours later...
    Annnnnd it's done! Well, operation 1 atleast. :P
    Attachment 244020
    Attachment 244022
    Turning the shaft around and boring out the shaft.
    Attachment 244024
    Making the labyrinth-seal for the front-bearings. I made the play around 0.2mm/side.
    These 2 are made of Stavax, because it is rust-resistant.
    Attachment 244026
    Attachment 244028
    I lathed the front-lid for the spindle and drilled the holes for mounting. But I accidentally f*****-up.(got the hole and head clearance off-center to each other) To fix it, I used the sinker-EDM(sure i could've fixed it in the mill/drill-press, but it looks muuuuch better EDM'ing it! ). Cylindrical ground a electrode for me to use.
    The front-lid is made of Stavax too, for it's rust-resistant properties.
    Attachment 244030
    Attachment 244032
    Attachment 244034
    Attachment 244036
    Attachment 244038
    While the sinker-EDM was running I made the drawbar in the lathe.
    It is made of Uddeholm Impax Supreme.
    Attachment 244040
    I sent all the Orvar and Stavax parts off to tempering! Now there around 52HRC hardness. Nice!
    Attachment 244042
    Now the precision work begins! For higher parallelness, I began with grinding the magnetic table.
    Attachment 244044
    Attachment 244046
    Surface grinding the parts to tolerance on both sides.
    Attachment 244048
    The spacer rings between the front AC-bearings need to have a really tight parallel tolerance, I measured the parallelism against a flat-surface and a 1µm dial-indicator. I measured the parallelism to 2µm on the bigger ring, on the smaller one it is 1µm. Yeah, I'm happy with the result.
    Attachment 244050
    Then off to the cylindrical grinder.
    Attachment 244052
    Mmmmmmmm... Ground parts!
    Attachment 244054
    And they fit, too!
    Attachment 244056
    Attachment 244058
    Attachment 244060
    Attachment 244062
    Measuring the axial-play in the labyrinth seal, turned out perfect!
    Attachment 244064
    Some ground and "to be ground" parts for the gripper assembly.
    Attachment 244066
    Time to grind the spindle shaft!
    First of all, I started grinding the tapered bearing-seat for the roller-bearing and measuring the taper in the measuring machine.
    Attachment 244070
    Attachment 244068
    Some hours later, it was finally done! And my god it is beautiful.
    Attachment 244072
    Next up, the test bar! Ground in a single clamping to get 0 run-out.(or atleast verrrryyyy little run-out)
    Made a short video confirming this.
    https://www.youtube.com/watch?v=I8nkFkNeFhU
    Attachment 244074
    Ground some small parts for the gripper.
    Attachment 244076
    I bought a roller bearing and some lock-nuts for the spindle.
    The roller bearing is a SKF NU 208 ECKP-C3, (I wanted a bearing with lesser play, but the only one they got was with C3 play, oh well.) This bearing is kinda special too, because of it's tapered bearing seat (1:12 taper).
    The nuts are SKF KMT 10 and SKF KMT 8, high-precision locknuts.
    I already got 2x SKF 7210 BEGAP AC-bearings from my previous spindle build, I'm re-using those.
    Attachment 244078
    Time to grind the thread for the lock-nuts! Yes, I said grind...
    Attachment 244080
    Attachment 244082
    Attachment 244084
    When the ATC is in progress, you want a stream of air to clean the taper, made a small hole (~1.3mm) through the drawbar to get that stream of air.
    Attachment 244086
    Attachment 244088
    Just for fun, I tried mounting the AC-bearings and the spacer rings and check the run-out of the bearings.
    Yeah, I'm quite happy with the result.
    https://www.youtube.com/watch?v=JG0BBG3qgeU
    Attachment 244090
    Ground the tool taper - check.
    Run-out of the bearing seats was around ~1-2µm.
    Feels like the run-out of this spindle is going to be really minimal. My guess/hopes are around 10µm, 200mm out from the taper(that's the length of the test bar).
    Attachment 244092
    Attachment 244094
    Time to sinker-EDM the large hole in the spindle for the drawbar assembly.
    Attachment 244096
    Attachment 244098
    Attachment 244100
    Attachment 244102
    And sinker-EDM the thread to hold the gripper assembly in place.
    Attachment 244104
    Attachment 244106
    A huge chunk of Uddeholm Impax, will be the spindle housing! Raw material weighs 23.3kg!
    Attachment 244108
    Attachment 244110
    Attachment 244112
    First tempo done. Should weight around 16-17kg.
    Attachment 244114
    Did the next tempo in the CNC-mill. Milled in the height and front diameter +0.2mm saved for grinding.
    Also drilled 2 holes thru the whole housing, those holes will be used as starting-holes for the wire-EDM.
    Attachment 244116
    Ground 2 electrodes to sinker-EDM the space where the gripper opens.
    Attachment 244118
    Attachment 244120
    Made some drive dogs, they are made of Impax.
    Attachment 244122
    Milled the electrodes for the "drive dog track" for the spindle.
    Attachment 244124
    Attachment 244126
    Attachment 244128
    Attachment 244130
    Milled and sinker-EDM some drainage tracks for the front-lid, so liquids don't enter/get stuck in the labyrint seal.
    Then I polished it.
    Attachment 244132
    Attachment 244134
    Attachment 244136
    Attachment 244138
    Time to fit the roller-bearing. Right now there is ~0.07mm radial play in that bearing, but I want a preload of a few µm. That's why the bearing seat have a 1:12 taper, the harder I tighten the nut the more the inner ring expands. That's why I need a spacer ring, ground to tolerance beneath the roller bearing so I don't over-tighten the nut and get too much preload.
    I used a dial indicator with 1µm resolution to check the radial clearance in the bearing, then I tightened the nut more and more until I got a pre-load. Then I measured the distance beneath the bearing with gauge blocks.
    Attachment 244140
    Attachment 244142
    Lathed, ground and sinker-EDM the gripper, All that's left is to split it in the wire-EDM.
    Attachment 244144
    Just for fun, I assembled most if the stuff I could. I can promise you, this is a sturdy piece of metal!
    Attachment 244146
    Attachment 244148
    Well, that's a few months work up til' now, hope you like it so far!
    I'm going to start wire-EDM earliest next week.
    If you have any questions or design improvements(It might be a little late for that now but one of the reasons I'm making this spindle is to learn something), feel free to tell me!
    Mar 2009
    39
    Re: BT30 spindle built from scratch, with ATC possibility.
    Wow.Beautiful work.Makes you appreciate what goes into the making of a spindle.As you say you have the machines and more importantly you know how to use them.Thank you for the pictures.
    What improvements did you make from the first spindle you made?
    Nov 2007
    2151
    Intense tools and skills you have going.
    My spindle has like 3 bellview set washer stack, I see like 15 in your drawing.
    Anyway very impressive work.
    md
    238
    Impressive.
    Now how much for one?
    Mar 2013
    20
    Thanks guys, I'm glad you like it so far! Right now the housing is being wire-EDM'd. I'll show a pic in a day or so.
    shedbob, About the design, here is the new vs the old one. Quite the difference if you ask me, hehe. Not only that, the shaft was made from some unknown steelbar, non tempered, the taper compared to the bearing seats had a lot of run-out, back-bearing no pre-loading, and so on...
    Attachment 244800
    mountaindew, I use 93 springs, 3 stacked parallel in 31 groups. At 50% compression one spring generates around 1000N force, I need around 3000N force, that's why I use 3 in parallel. I can't compress the spring more than 75% for maximum lifetime, the compression length between 50% and 75% is 0.125mm. I need around 3.5mm stroke + some safety margin, that's why I chose 31 stacks, that way I'll get around 3.9mm stroke and a force of 3000N.
    hjl4, Sorry, but it's not for sale.
    May 2005
    925
    Amazing build, thanks for showing it in such a detail...!
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    238
    I kind of figured "Not for sale".
    But if you made more then one, I bet you people would be interested.
    Business potential?
    Mar 2013
    20
    PEU, Thanks man!
    hjl4, Well, the thing is it would've been just as expensive or expensiver as a "real" BT30 spindle. The amount of time i put into this spindle is huge! And because more or less all the stuff i do is in manual machines it doesn't go quicker to make one or 10 spindles. And one more reason, I don't want to "mass produce" stuff for others at my job, I got the great privilege to use the machines after work, I wouldn't want to loose that for anything.
    Mar 2013
    20
    When I got to work this morning the wire-edm had only run halfway, started it again after work. It SHOULD be done tomorrow morning.
    Oct 2010
    1189
    So we share that Privileg great
    Question do you do wire EDM at home and if Yes is it a build or bought one ? EDM is now on my List ..
    Mar 2013
    20
    Tkamster: Lol, I don't own a wire-EDM, my job got one. :P
    Here we go! Wire-EDMing done!
    Attachment 245044
    Started machining the first bearing seat, got really bad surface finish, but that doesn't matter, will grind it later. :P
    Attachment 245046
    Mar 2013
    20
    Time for another update!
    Milled the back bearing seat in the housing today, left some material for grinding.
    Attachment 245116
    I also made a "clamping plate" for the grinder/housing for better clamping when grinding.
    I MIGHT start the cylindrical grinding tomorrow, if not then i'll do it in 2 weeks.
    Attachment 245118
    Attachment 245120
    Oct 2010
    1189
    Hi is it RAM or wire EDM ,..
    Mar 2013
    20
    RAM? The only RAM I know is for computers, haha!
    It's a wire-EDM.
    Feb 2007
    711
    looks like he has wire and ram / sinker edms.
    Oct 2010
    1189
    Now i am jealous ,..
    Mar 2013
    20
    The gripper is finally done!
    There was a slight problem when splitting the part tho, wasn't clamped good enough so it moved.(check the pic below, you can see a mark in one of the petals.) But I think i'll work anyway, I really don't want to make another one... Took me 2 full days to make this one.
    Attachment 246748
    Attachment 246750
    Here's the gripper assembled.
    Attachment 246752
    Attachment 246754
    And a inside shot, too.
    Attachment 246756
    Attachment 246758
    And it works too!
    Attachment 246760
    I tried grinding the housing in the manual grinder a week ago but the machine was too weak(actually, the morse taper is too weak which holds the magnetic chuck).
    I asked my colleague if he could help me in the cnc cylindrical grinder, he agreed. He was going to help me today but had a job rigged in the machine, we'll see next week if he's able to help me.
    Oct 2010
    1189
    Great work question are your grippers hardened ? And did you use a plan or did you Design it yourself ?
    Mar 2013
    20
    Thanks man! It's made of Uddeholm Impax, a pre-hardened tool steel; should be around ~30HRC. Tho I'm thinking about plasma nitride these to get a hard surface, around ~58HRC if I remember correct.
    Yes, I designed this myself, in fact every part in this spindle beside the bearings and the bearing nuts is my design. Tho I did a lot of research, looking at commercial spindles and such when designing it.
    Oct 2010
    1189
    Cool i also about to do similar at existing iso 30 spindle to factor atc able ,..
Page 1 of 3 123
  1. Home Designed Scratch Built CNC Lathe
    By Chrisjh in forum Videos
    Last Post: 11-07-2013, 09:40 PM
  2. My scratch-built plasma table
    By grahamcowan in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-19-2013, 05:21 PM
  3. Looking for Specs for a scratch built lathe
    By breathe in forum Vertical Mill, Lathe Project Log
    Last Post: 06-16-2011, 12:56 PM
  4. Mini 3 Axis CNC scratch built
    By Seraph in forum Vertical Mill, Lathe Project Log
    Last Post: 03-19-2008, 09:58 AM
  5. Advice on Small CNC Mill - From Scratch or Pre-Built?
    By DrCNC in forum Benchtop Machines
    Last Post: 11-30-2006, 01:29 PM
