588,002 active members*
3,239 visitors online*
Login Register
EZCAM Forum
UCCNC Control Software > UCCNC Linear Tool Changer
Results 1 to 2 of 2
    Oct 2019
    Hi.
    I have a CNC Router that I built. It is 2.7m x 1.3m. I use it primarily for timber and Foam.
    I have just purchased an ATC Spindle and thought that setting up the tool rack would be easy...........
    My setup for the tool rack is fairly simple. 20 Tool Holders spaced across at one end of the machine. This still gives me a cutting area of 1.2mx2.4m.
    The rack is fixed in position, gantry moves past the end of the cut area, changes tools, moves to a sensor to set the Z offset and then progresses with the job.
    Can anyone point me in the direction of a plugin for this?
    Thanks.
    Mark
    Re: UCCNC Linear Tool Changer
    Here is a sample macro:
    https://cnc4pc.com/forum/projects/to...acro-for-uccnc
    It is a carousel type, but you can change the script.
    Arturo Duncan
    https://cnc4pc.com
  1. NEW ATC CNC ROUTER RC1530-ATC WITH LINEAR TOOL CHANGER
    By Baiansy in forum Roctech CNC Routers
    Last Post: 10-21-2021, 12:54 PM
  2. ELECNC 6090 engraving machine with linear tool changer
    By elephantcnc in forum News Announcements
    Last Post: 01-03-2020, 06:32 AM
  3. Linear Tool Changer
    By shahabazmoodeh in forum Uncategorised CAD Discussion
    Last Post: 12-25-2016, 02:16 PM
  4. CNC ROUTER MACHINE RC1325-ATC WITH LINEAR TOOL CHANGER
    Last Post: 05-22-2015, 09:32 AM
  5. New machine_Auto tool changing with linear tool changer
    By bellawyl in forum News Announcements
    Last Post: 11-01-2012, 07:50 AM
