588,476 active members*
5,020 visitors online*
Login Register
EZCAM Forum
EMCO Lathe > Concept Turn 155 Turret Make / Model (Live Tooling)
    Jan 2006
    177
    Folks,
    Any chance someone with a Concept Turn 155 that has the turret with live tooling could drop a reply here with the manufacturer and model number info or a pic of the model plate? I'm looking at a retrofit of one where the machine is like new, but it was the "economy" model with the more basic turret and I'm on the lookout for the more capable turret so I can do a bit of an upgrade.
    Thanks!
    May 2016
    320
    Re: Concept Turn 155 Turret Make / Model (Live Tooling)
    My 325-II uses a Sauter 0.5.474.510 turret. I believe the 155 used the same turret when the live tool option was fitted.
    Sauter still has a 0.5.473.5xx turret listed on their site and it appears identical to mine.
    If you do find one, be prepared for some financial pain when tooling it up with live tools. While they're not as expensive when new as bigger VDI holders or BMT, unlike the more common sizes VDI16 live tools are essentially unobtainium on the used market.
    I've been searching world-wide for 4 years, and I've yet to find a used live tool that fits the Sauter turret & drive. New - axial are about $1100 and radial are about $2k.
    Jan 2006
    177
    Much appreciated. I just figured I'd put the question out there so I know what to keep an eye out for, should one happen to pop up somewhere. I realize that I'm more likely to come across another complete lathe that has the c axis and turret I'm looking for than to find the turret by itself, but since these things only come up once in a while, figured it can't hurt to ask. The 325-II is the model that I ultimately would love to have so I could eliminate a ton of second op work, but they're rare as hens' teeth. While the live tool holders are crazy expensive, I could actually recover the cost pretty quickly in saved second op labor time. I have a few parts that could be run lights out and never need to see a second op in the mill.
    May 2016
    320
    Yea, I've never seen an appropriate turret for sale by itself, nor a 325-II being parted out in the 4 years I've had mine. I think I've seen two on ebay and perhaps six or so complete lathes for sale on the worldwide market.
    I think it would be cheaper, and maybe easier, to just get a 2nd op lathe and set up a part-loader of some sort than try to retrofit a live-tool turret. Something like an Omniturn maybe.
    Of course for unattended operation, you'll need a bar feeder. 24" of stock in the spindle just doesn't last very long and reloading the lathe every 20 minutes gets old. I recently stumbled across an LM800 and am about 95% of the way to getting it working with my 325-II.
    Since the LM800/1200 are even more rare than complete lathes... if you've got the room a hydrobar-style feeder would be fairly easy to connect and would eliminate having to cut bars to spindle length.
  1. Puma 2500LSY live tooling squeal from turret
    By Silv3rDragon in forum Daewoo/Doosan
    Last Post: 01-03-2023, 03:57 AM
  2. Emco Concept Turn 155 ACC
    By Fire_in_the_hole in forum EMCO Lathe
    Last Post: 09-12-2022, 02:13 PM
  3. Replies: 0
    Last Post: 03-17-2016, 09:21 PM
  4. Replies: 1
    Last Post: 05-26-2012, 09:29 PM
  5. BMT Turret Live Tool Design Concept
    By selvaraj205 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-26-2008, 04:03 PM
