588,288 active members*
5,142 visitors online*
Login Register
EZCAM Forum
Fanuc > Bat alarm flashing Fanuc 16ttA controll
Results 1 to 6 of 6
    Apr 2003
    76
    Hi All,
    I have a problem and not sure what the next step should be.
    My controller is flashing BAT. We have changed the batteries and it still flashes.
    We had Fanuc in and they replace all the boards and it still flashes.They had no ideas as to the cause and left.
    I have stared and the electrical book for hours looking for a timer or what else could be generating this alarm.
    I cannot seem to find anything.
    Has anyone here had a problem like this before and if you did what was your fix?
    Real poor practice to leave the machine on 24/7 when its used once per week for 8 hours.
    Apr 2009
    1383
    Re: Bat alarm flashing Fanuc 16ttA controll
    The battery is in the power supply unit (right-most one). The battery monitor circuit is most likely there too. The 'battery low' signal most likely goes to the main cpu board (A16B-2200-0900) via the back plane. These are the most likely places to look.
    Apr 2003
    76
    Well I thought I solved my problem by selling the machine. Wrong People came back and asked me to look into a new issue
    They have wired up the machine and now when it powers up the controller only shows that the SLOT CONFIG and shows ),1 and 2 with numbers but nothing more.
    In the back however I checked the Battery and its good, The PIL light is greel on the Power Supply
    The Main CPU Board however shows a problem
    On the status lights # 2 is not lit. On the alarm lights though #2 is red.
    By the books I am not sure but I think the issue is the machine is waiting for other CPU's answers (ID setting)
    What is my next step to solve this? Thanks for the help.
    Apr 2003
    76
    You were exactly right, A break in the back plane that was almost invisible. Repaired it and machine came back to life.
    Reloaded the parameters and the Password protected parameters and machine works.
    Thank you memoryman
    Apr 2009
    1383
    You're welcome; I had forgotten about this one!
    Bom dia, estou exatamente com o mesmo problema no meu Fanuc 16TT, substitui a bateria mas mesmo assim não para de piscar.
    Podem ajudar.
    Não encontro falha.
  1. FANUC 16TTA CONTROLLER
    By veeru8772 in forum Fanuc
    Last Post: 02-09-2014, 07:12 AM
  2. FANUC 16TTA CONTROLLER
    By veeru8772 in forum Spanish
    Last Post: 02-09-2014, 06:29 AM
  3. Replies: 0
    Last Post: 02-08-2014, 12:26 PM
  4. Fanuc 16TTA on Nakamura TW-10 Error 972
    By bensttech in forum Fanuc
    Last Post: 02-08-2014, 12:23 PM
  5. Need Help Alarm Flashing
    By Pmp Audio in forum Fanuc
    Last Post: 06-24-2009, 03:46 AM
