I bought this machine from the original owner at an online auction, so I wasn’t able to run it prior to purchase. I was told everything worked fine, but it had been sitting for “about 10 years”. Once I got it in my shop, I booted it up and got a some errors.
CMOS system options not set
CMOS display type mismatch
Run setup utility
Press F1 to resume
I did a little reading, figured the battery on my motherboard was probably bad, so I booted it up to verify and got a different error message this time.
CMOS battery state low
Run setup utility
Press F1 to Resume
Ok, yep the battery was reading under 1V even when the machine was left off for 30 minutes. Ordered a replacement and got it swapped out. Now I booted up the machine again and the message I get now is:
CMOS checksum failure
Run setup utility
Press F1 to Resume
So I’m guessing I need to get the backup programs and reload everything? I have searched around and have found a few things, but not a lot of solid information on this machine. I’m guessing this is an EZ Path S?
The ID tag on the machine says:
Serial number: 002-077587-325
Model: EZ Path
Date: 28-3-94
So I guess my questions are
1. Any idea what these errors mean?
2. Do I need to get the disks and reload the operating system?
3. Would this be an EZ Path “S”? I can’t find that identification anywhere on the machine.
Thanks in advance for any help
