588,093 active members*
4,723 visitors online*
Login Register
HEIDENHAIN Forum
Fanuc > Differentiating between macro variables on two-sided lathe
Results 1 to 2 of 2
    May 2020
    12
    Question Differentiating between macro variables on two-sided lathe
    Hi Eveyrone:
    I've got a bunch of Fuji ANW-series lathes that use Fanuc 0i-Td controllers. These are twin-spindle lathes that have totally independent sides, left and right.
    I want to import compensation data to my machine and then use it to adjust my wear offset, essentially making a localized workshift.
    The thing is, my software allows me to write to the macro variables, (for example, #500), but I don't know how to tell the left-side #500 from the right-side #500.
    I'm assuming they are at different addresses in the overall NC memory map; after all, the controller knows when the LS calls #500 not to use the RS value.
    My question is how can I find out the memory locations of these different registers. We need to make sure the compensation value goes into the correct side's #500, or we'll end up making a mess of it all.
    Any help is appreciated!
    Thanks!
    Nov 2007
    364
    Re: Differentiating between macro variables on two-sided lathe
    open up the Macros and use #500 left side and #600 right side same as tool offsetts ----Even one head and odd on the other so you know what side you are offsetting
  1. 4 axis Lathe Macro Variables - Fanuc Oi-TD
    By dafrenchman in forum Fanuc
    Last Post: 01-14-2021, 11:10 PM
  2. Macro Variables
    By donwatt in forum Controller & Computer Solutions
    Last Post: 06-25-2010, 06:30 PM
  3. macro variables
    By sinha_nsit in forum Fanuc
    Last Post: 01-15-2008, 10:42 AM
  4. Variables/Macro uses....
    By theemudracer in forum Fanuc
    Last Post: 12-13-2006, 08:45 PM
  5. Variables/Macro use ????
    By theemudracer in forum G-Code Programing
    Last Post: 12-11-2006, 04:47 PM
