588,613 active members*
6,677 visitors online*
Login Register
HEIDENHAIN Forum
Open Source Controller Boards > Open Source Boards Available, Stepper Drivers and Break Out Boards - Page 36
Page 36 of 39 263435363738
Results 701 to 720 of 763
  1. #701
    Feb 2005
    130
    external Schottky for a3977
    Thero use BYV27... on http://www.students.tut.fi/~kontkant/a3977.php.html
    Quote Originally Posted by allegro-faq
    Q13...Use of external Schottky diodes with low Vforward, to clamp the outputs to VBB and ground, will help to reduce the power dissipation in the A3977. ....
    Q15...We typically don't recommend a specific diode due to the range of voltages and currents that can be used.
    byv27.. uf5400, fr303, sb540, mbr760
    what type of diode you recommend ?
  2. #702
    Mar 2005
    523
    hello
    i c that the 3977copper.zip has a png extension.
    do you have this in gerber of tiff format as i cannot read or convert a png file.
    or do u have a png converter
    thanks
  3. #703
    Mar 2004
    222
    attached is tiff version of single sided joe's version.
    you might want to check it, I cleaned it up a bit
    with image editor, but I can assure you it's the
    same, I already built a working board with it.
    Attached Files Attached Files
    mhel
    "This is intentionally left blank."
  4. #704
    Dec 2004
    3
    Hi guys,
    I am relatively electonicly challenged, but can solder etc. I found this unipolar chopper circuit on the net and am looking for comments on whether this will work. It is baed around the l297/9 chips. I have these chips and are thinking of substituting the fet for IRF540N's. Will this work? or is the circuit incomplete?
    Look forward to your input.
    BRG
    Andy J
  5. #705
    Jun 2003
    3312
    Andy same concept as the L297uni on my website. It just uses the L298 to driver the Mosfets. With logic level mosfets getting so inexpensive and robust, the cost of the L298 VS a 74HC08 (or 74AC08) isn't worth the difference.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  6. #706
    Dec 2004
    3
    Quote Originally Posted by pminmo
    Thanks for the reply Phil, had a look.
    Em, your circuit has diodes in the return lines and the one I have been contemplating hasn't? I presume that this will be ok as is? or would you suggest any improvements?
    (I'm pretty skint at present and as I already have the 297's/8's and the rest of the components, would you suggest going ahead and trying it ?).
    Please excuse any dumb questions..... I'm sorta trying to learn this on the fly.
    Brg.
    Andy
  7. #707
    Jul 2005
    27
    Phill, better than 74HC08 is 74HC09 for your 297unip. do you think so?
    _____________________________________________
    Hare Krishna Hare Rama
  8. #708
    Jun 2003
    3312
    No it would be worse!
  9. #709
    Oct 2003
    46
    Hi are there any open source bipolar board designs available that are capable of at least 4 amps per phase
    I'm also planning on using Mach3 it's not open source but its free for me because my code won't come close to 1,000 lines if I ever get my router finnished ,but I'll probably my Mach3 anyway as I like it . and for the money it's a deal so are there any open source bipolar designs capable of 4 amps per phase that would also work with Mach3
    Thanks Bob
  10. #710
    Feb 2005
    130
    Quote Originally Posted by bobleecnc
    Thanks Bob
    yes... bipolar and 4A
    and 1/2 step
    http://engraving.majosoft.com/html/b...and_L6203.html
    or...
    I don’t have tested this
    link to project: http://www.cnc.info.pl/viewtopic.php?p=16082
    and info: http://forum-cnc.pl/viewtopic.php?t=55
  11. #711
    Oct 2003
    46
    Thanks Mark That helps do you know about how much it cost to build it ?
    also one more question do you or anybody else know where I can find some specs. on some old vexta ph299-01 motors or would some one have that info to share with me ? particularly interested in both bipolar and unipolar holding torque's ? Thanks again Bob
  12. #712
    Feb 2005
    130
    yes... cost in zł
    l297 - 11 zł
    l6203 - 12 zł
    1 usd = 3,2 zł
  13. #713
    Jun 2005
    3
    Does anyone knows a 3 axis board controller avaiable for EMC? The tachus42's it's a good idea but I don't have place for big resistors and isn't avaiable for EMC. Thank's so much.
    Haroldo
  14. #714
    Jun 2003
    3312
    bobleecnc,
    Eventually, but it's not there yet.
  15. #715
    Jun 2003
    3312
    backhar,
    The interface board in conjunction with the individual driver boards are compatable with emc.
  16. #716
    Feb 2005
    130
    lpt setup...
  17. #717
    Jun 2003
    3312
    I just added a link to a new 4 axis interface on my website as well as a webpage on an engraver used with the 3977's.
  18. #718
    Jun 2005
    3
    Thank's for this table.
    Pminmo, do you have a schematic of current limiting resistor board for example? Do I use one resistor for each coil?!
  19. #719
    Jun 2003
    3312
    BackHar,
    I can't say that I would recommend using a non chopped board. Yes it's cheap, its a good learning tool, it will run machines, but it's not a "performance driver".
  20. #720
    1050
    Hi Phil
    Got the PCB's done for the L297 Uni and finding it difficult to trace out the BZW04-48rl, would u suggest something else, also the LM319HVT is not available in the To220 package but in a big ugly steel type thing. how to get thu this.....
    Regards
    Irfanulla
  1. Best break out boards?
    By Nigel Tufnel in forum Stepper Motors / Drives
    Last Post: 12-27-2013, 07:12 PM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
