588,103 active members*
5,006 visitors online*
Login Register
HEIDENHAIN Forum
Stepper Motors / Drives > Best break out boards?
Results 1 to 3 of 3
    Nov 2013
    29
    Is there a break out board brand or source that is generally accepted as the best/most reliable? Seems Gecko is the brand of choice for stepper drivers, what about break out boards? Who's the best?
    Looking for a board for a benchtop mill conversion. Would like it to be able to handle the following:
    -coolant on/off,
    -stepper motors
    -VFD control
    -MPG capability
    -linuxCNC
    -plus what ever typical function I'm neglecting cause I'm still a newb.
    Any info appreciated. Thanks.
    35538
    PMDX
    Jul 2003
    1760
    PMDX is a good company
    For linuxcnc though - I would look at mesa. You can get a 5i25 + stepper daughter board for about $200. This gives you 5 axis step direction outputs, spindle encoder, analog output, 48i/o plus it is vey expandable. (this moves the pwm, step and encoder counting outside of the computer so they are very high speed)
    sam
  1. Open Source Boards Available, Stepper Drivers and Break Out Boards
    By pminmo in forum Open Source Controller Boards
    Last Post: 06-23-2018, 01:46 AM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
