Been exploring the move command in the help files and see that the point selection when used in conjunction with direct auto as the link, the rapid moves move down to a z amount desired.
Is there another way to move the rapid moves with drag select or polygon pick? The reason for this is that while the example has just a few points, doing that for 100 rapids would take too long to pick both ends of each rapid move. I have tried both the drag select or polygon pick but it seems to shift down the vertical rapid as well but placing the horizontal rapid per the z amount.
http://bobcad.com/wp-content/helpfil...ve_Example.zip
