586,108 active members*
2,941 visitors online*
Login Register
HEIDENHAIN Forum
X3/SX3/G0619/G0463 > New Motor to SIEG X3
Results 1 to 3 of 3
    Sep 2021
    Exclamation New Motor to SIEG X3
    I have just bought me a SIEG X3 Milling Machine, but it just got 1800 RPM. Can`t mill Aluminum.
    Is there anybody that can tell me if there is a replacement motor to this machine that have around 10.000 RPM and what I have to do to get this RPM.
    Must be 220 Volt.
    Jul 2009
    85
    Re: New Motor to SIEG X3
    Don’t limit yourself to 220 v motors only.
    You’ll be much better off getting a three phase motor and a variable frequency drive.
    Although the spindle bearings on the X3 may not do very well with speeds your looking to run.
    Jan 2018
    1516
    You need to look into changing pulley ratio's or a belt conversion if geared. You'd prob blow spindle bearings above 6k rpm.
    You can mill ally at those speeds, just a little bit slow. High DOC with lower SFM and feed. (unless using small size cutters).
  1. Sieg X3 Spindle motor
    By rcotteleer in forum Benchtop Machines
    Last Post: 09-29-2010, 09:25 PM
  2. sieg X3 spindle motor specs
    By daedalus in forum CNC Machine Related Electronics
    Last Post: 07-03-2007, 02:16 PM
  3. Diagnosing the Sieg 7X Motor
    By RotarySMP in forum Mini Lathe
    Last Post: 04-20-2006, 07:43 PM
  4. Upgrade Motor for a Sieg X3
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 06-22-2005, 01:14 AM
