586,103 active members*
3,531 visitors online*
Login Register
HEIDENHAIN Forum
Mini Lathe > Swapping out F/O/R changeover switch with new style
Results 1 to 1 of 1
    Nov 2007
    361
    I need help with my wiring on this Cj0618 mini lathe . The forward / off / reverse switch became too worn and starting giving me issues so I decided to change it out with the type that comes on a grizzly mini lathe ,the only issue ...well there are several but the main issue is the style I am wanting to go with is an adiele from Amazon part number LW28-20/3 12 terminal 3 position. The old switch was a E-TEN403 switch pictures attached . I tried to take 1 wire off at a time and mount it on the new switch but the switches are made different the new switch pinout is in position 1 ...1-2 , 5-6,9-10 and in position 2 .....3-4,7-8,11-12...The old E-ten403 switch was position 1....1-2,4-5,7-8,10-11 position 2 is 2-3,5-6,8-9,11-12.. I have notes of where each wire went to the old switch I just can't wrap my head around it . Has someone done this before meaning change out the old style switch with the newer style ??maybe the pictures will help
    Attached Thumbnails Attached Thumbnails 16432462615502702671027321742353.jpg
  1. TTS to BT30 Changeover? Cheap Arbors?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 12-06-2019, 02:28 PM
  2. axis changeover
    By gardon in forum Cincinnati CNC
    Last Post: 01-23-2016, 11:28 PM
  3. 20 degree chamfer with R1,5 on the changeover to the drill hole
    By robbi01 in forum HEIDENHAIN -> GENERIC
    Last Post: 11-13-2011, 08:10 PM
  4. Super MiniMill Vise/Rotary Changeover
    By Geof in forum Haas Mills
    Last Post: 01-05-2010, 06:49 AM
  5. VAC III Changeover
    By Juanjo in forum Okuma
    Last Post: 03-23-2009, 08:40 PM
