586,094 active members*
3,912 visitors online*
Login Register
HEIDENHAIN Forum
Dmm Technology > Wiring up a Dyn2 drive, pr. DMM's schematics
    I am looking for inspiration as to how people on here have wired the two capacitors needed pr DMM's wiring diagram for the DYN 2's. just trying to get a clean setup and a safe mounting for the two circular capacitors.
    I attached the wiring diagram for anyone wanting to chip in even if they don't have the same set-up
    Re: Wiring up a Dyn2 drive, pr. DMM's schematics
    Dang, I was going to post this in the DMM section,not the EMCO section.
    Dec 2013
    5717
    I moved the thread to the DMM forum
    Capacitor mounting brackets are available, you only need to choose the proper size, or you could just make your own
    https://www.alliedelec.com/passive-a...ting-brackets/
    Jim Dawson
    Sandy, Oregon, USA
    May 2006
    25
    Thank You ! Will 3d print some for my box.
  1. DYN2 drive issues
    By Travis1581 in forum Dmm Technology
    Last Post: 04-14-2023, 06:58 PM
  2. taig/dmm/dyn2/acorn settings
    By Grascochon in forum Taig Mills / Lathes
    Last Post: 04-01-2020, 03:52 AM
  3. Linuxcnc/DYN2 DMM-Tech Drives using 5I25 _ 7I76 Combination
    By bill south in forum LinuxCNC (formerly EMC2)
    Last Post: 02-03-2020, 07:28 PM
  4. Linear Toroidal PSU for DYN2+400W DMM servos
    By rvectors in forum Dmm Technology
    Last Post: 06-25-2019, 07:11 PM
  5. wiring dmm dyna 4
    By baxter435 in forum Dmm Technology
    Last Post: 11-15-2016, 03:42 AM
