586,115 active members*
3,348 visitors online*
Login Register
HEIDENHAIN Forum
X3/SX3/G0619/G0463 > Sieg X2 milling machine alignment issue
    Apr 2023
    9
    Can you help me with this?
    https://www.youtube.com/watch?v=jCrm...=LeandroFeigin
    Thank you!
    Re: Sieg X2 milling machine alignment issue
    you can shim the column . I've had to do that with mine
    Apr 2023
    9
    Quote Originally Posted by metalmayhem View Post
    Thanks for your reply! I have 2 questions for you.
    1) Where should I exactly place the shims?
    2) Did you lose to much rigidness by shimming it?
    Thanks!
    you can shim it where the column mounts to the table or at the swivel , I shimmed at the swivel . As far as rigidity goes there are far greater factors working against that than any amount of shimming will
  1. Sieg X2 3 Axis CNC Milling Machine + Tooling
    By bksaccount in forum For Sale Only
    Last Post: 08-11-2014, 06:06 AM
  2. Replies: 3
    Last Post: 09-20-2013, 01:21 AM
  3. Sieg X3 Milling Machine CNC Conversion Project
    By Bird_E in forum Vertical Mill, Lathe Project Log
    Last Post: 11-30-2009, 05:31 PM
  4. Sieg X3 CNC Milling machine for sale
    By Charles09 in forum MetalWork Discussion
    Last Post: 06-13-2009, 01:24 AM
