586,357 active members*
3,341 visitors online*
Login Register
HEIDENHAIN Forum
UG NX > Resolution Issue or Tool Path Issue?
    Dec 2015
    5
    Hello all! I am a long time NX cad user, but very much a newbie when it comes to the cam side and trying to teach myself in preparation for a mill. Going crazy looking at the 3d body left after a planar profile command. One corner is sharp as it should be, the other has the corner knocked off slightly. In my cutting parameters I have corners set to extend. These parts are patterned in the same orientations across a pallet and have this issue but in no specific order. So, am I going crazy looking at a resolution problem or is this something I would want to figure out before actually attempting to mill the parts? Thanks for dealing with a newb!
    Attached Thumbnails Attached Thumbnails Part Orientation.png   Incorrect Corner.png   Correct Corner.png
    Dec 2008
    3111
    Re: Resolution Issue or Tool Path Issue?
    It could be resolution....
    Check the toolpaths to see if the deviation from expected sharp corner is still sharp.
    See if you can backplot it on-screen, by stepping each move... see if it adds endpoints at the corner in question.
    It is the actual toolpath that dictates the shape on the CNC, not any toolpath simulation done on-screen
    Quote Originally Posted by Spydie View Post
    Looks like resolution issue.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2015
    5
    Quote Originally Posted by Superman View Post
    Okay, I won't sweat it too much then till I get the machine in and start running test parts to see. I'll take a look and see if it add's any end points as well like you said. Thank ya!
    Mar 2023
    6
    Just checking in, did you get your program working?
  1. V25 Indexing/Tool Path Pattern Problem - Build Issue?
    By magicniner in forum BobCad-Cam
    Last Post: 06-16-2016, 11:03 PM
  2. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  3. Tool Path Issue
    By Jamespvill in forum BobCad-Cam
    Last Post: 02-12-2015, 05:19 AM
  4. Multiple profile operation tool path issue
    By Craigpat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-25-2014, 09:38 PM
  5. Tool Path Generation Issue
    By ianober in forum BobCad-Cam
    Last Post: 03-11-2009, 07:42 PM
