588,323 active members*
4,314 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Rutex Products > Limit switch help on 2110 motherboard
Results 1 to 2 of 2
    1880
    I am having a heck of a time getting my limit switches to work.
    My computer is giving a solid 4.9v through the printer port and then coming out of the rutex board I am getting a whopping 1v through the limit switches
    5v limit switches I know are bad enough with noise as it is but with the measly 1v I am getting from the mother board I get a false switch trigger just by thinking!
    any help would be great!
    IE how to get that 1v up to the target of 4.9v
    or if there is a way to change to 24v without massive changes that would be awesome too!
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Feb 2007
    4553
    Re: Limit switch help on 2110 motherboard
    Michael T,
    I believe Rutex suggests a second (additional parallel port) and breakout board for limit switches.
    A Pokeys I/O board would be a much cleaner and elegant solution, they have both USB or Ethernet models.
    PoKeys I/O devices
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  2. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  3. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
