Design. Make. Inspect.
Not sure what I want.... I have many adaptors, the drill bit adaptor with head. I will gather all the information in tonight and post. Here is a list of the issues I have had (with the stronger spring).
Dust collects between the head and the adaptors, making if very hard to remove the adaptor till you get the dust out.
Even at 10K to 12K (as many have proved you can run), the adaptors will spin in the head unit when a high strees zone is hit (really obvious in oak with the grain gets tight). This cause a side effect of removing the finish of the cutters.
For some reason I can not longer get the V cutters to spin true when using it true
Noise level from the router is much higher with the attachment in versus out. My house is much quiter running the router without it in.
Greetings.
I have been following the thread about the tool changer in silence.
I am planning to build a CNC mill and would love to have a tool changer.
Can I also get a copy of the plans, please?
fruktodlaren(a)gmail.com
Best regards
/Tony from Sweden
I have uploaded the information on the tool changer I am going to sell on my web page... once the information is gone the unit is sold... www.cncmachine.phillipsfamily.ca
good job
Where can I buy this rapid changer tool?
where can i buy this rapid changer tool?
hi is there an update about the tool changer
HiTech systems no longer make the adaptor the changer used so you would need to find another system.
