588,018 active members*
8,278 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Mass finishing equipment/media/strategies > Home Anodizing. Low Current Anodizing. 720 Rule
Results 1 to 5 of 5
    Aug 2006
    2758
    Some time ago, while browsing on the internet, I found out about the Low Current Anodizing method (LCA). This method has been popularized by Caswell (Plating Kits Electroplating Kits Aluminum Anodizing Kits Powder Coating Systems Metal Polishing And Buffing Supplies - Caswell Inc ) and there are a lot of DIY videos on the web about it.
    One of the most frequently asked questions about anodizing is how to calculate the time needed to anodize to a certain oxide layer depth. Browsing again I found out about the 720 rule.
    This is a small java program I made a couple of days ago directed to calculate the anodizing time given the part's surface area, current density (it is directed to users of constant current anodizing rectifiers), and desired oxide layer's depth in mils.
    The software was written for a group of users from Spain, so the main screen comes up in spanish but there is a checkbox selection for english speaking users. Surface area can be entered in in2 or cm2.
    Current densities are limited to the range used by the Low Current Anodizing (LCA) method (2 to 8 Amperes/ft2).
    In order to use it simply extract the compressed files into a folder anywhere on your computer and execute (double-click) the file "720RuleCalculator.jar". It will work on any operating system (Linux, MS Windows (all versions) and Mac OSx). No installation is required.
    Enjoy!!
    kreutz
    Attached Files Attached Files
    Oct 2005
    169
    Thank you for sharing this. I have a small hard chrome tank and I am interested in anodizing and black oxide so this may be handy for me in the future.
    Cheers!:banana:
    Aug 2006
    2758
    Thanks,
    kreutz
    Oct 2012
    3
    Re: Home Anodizing. Low Current Anodizing. 720 Rule
    You should post this with sourcecode on github Master
    Sep 2019
    5
    Perfect timing,I am trying to get setup to anodizing for the first time on a hobby type person level.This is good information so thank you for posting
  1. Home Anodizing
    By missing link in forum MetalWork Discussion
    Last Post: 04-26-2011, 01:44 AM
  2. anodizing
    By pyroracing85 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:22 AM
  3. RFQ anodizing
    By bucont in forum Employment Opportunity
    Last Post: 03-22-2007, 08:14 PM
  4. anodizing aluminum at home
    By triump in forum Mass finishing equipment/media/strategies
    Last Post: 11-12-2006, 07:58 PM
  5. Anodizing?
    By Klox in forum MetalWork Discussion
    Last Post: 05-03-2005, 06:46 PM
