588,487 active members*
5,150 visitors online*
Login Register
HEXAGON - Banner
HEXAGON Forum
Design. Make. Inspect.
FineLine Automation > My second CNC router
Results 1 to 8 of 8
    Sep 2007
    52
    This is my second Fineline Automation router...My first was a 2x4, and this one is a 4x4 with the addition of a built in 4th axis rotary attachment...The rotary is a gear drive unit with a 4 jaw chuck, that has the head stationary, and the tail stock is movable and slides along the 4x6 aluminum extrusion..The actual working field of the rotary is 8x42...I have not as yet used it because I have been busy trying to make guitars...The rest of the info on this build is that it has a Vital Systems Hicon Integra 6 axis board, and yes I intend to add another axis as it is a simple matter now..It also has a 3HP 220V air-cooled spindle...It is running on Mach4 on a Dell Inspiron tower computer with a 24" Acer touch screen monitor …..I do not have a vacuum system hooked up to it yet, but I do have a vacuum system...I have a complete Pepperl + Fuchs Proximity Sensor Kit, but have not hooked it up yet and have not needed it, because of the way I am doing it now....
    Back to the machine now..At least for me, I have found the Fineline units to be rock solid in use, and is built like the brick house you hear about...So far I have cut out 3 bodies and a bunch of necks with mistakes on my part, not the machine and it does so with ease....Like anything else that is related to this, what you put in is what you get out....So there is mine......
    Nov 2014
    722
    Re: My second CNC router
    That looks great, Joe! Where can we see your guitars? I have built one acoustic and plan to build more, maybe even some solid body electrics one day. Which CAD/CAM system are you using?
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Sep 2007
    52
    I made some guitars for my son and will leave it at that because I was here to talk about the machine...The software I have is V-Carve pro, Alibre, Desk Proto, and Fusion 360...I am 74 and still trying to learn how to use all this stuff..I mostly just fool around and see what I can do...I also like to do wood gear clocks, but have only made parts so far...I enjoy making the machines more than making things with them...I have converted a few milling machines to CNC also, but have gotten away from metal work...
    Sep 2007
    52
    I did put some pics of my guitars on here on Musical Instrument Design and Construction, which I thought would be better than posting them here as this is for FLA machines...
    Sep 2005
    1740
    Joe I will be 77 next month and I just sold my 4x4 FLA machine, it was too large for me to mess with and I had a mild stroke this January so it went to a good home. I have converted a few machines in the past but for my last machine I built up a 1000 x 750 (mm) WorkBee from a kit and used my experience with Mach4 to set it up with a PMDX controller (USB) so far its checking out just fine. I had zero issues with my FLA machine
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Sep 2007
    52
    The FLA 4x4 is a big machine, but that helps make it solid...I cut a pocket 1" deep in one pass with a 1/4 endmill, I did it slow but it did it...I did at one time look at the Work Bee, and gave it some consideration, but at the time I did not know which way I wanted to go again.....It looked like a nice machine...I also have one of those 6040 machines all set up and ready to use, but never used it...It has a water cooled spindle and I added a nice pendant...I had thought of selling it, but just never did....
    56
    Joe, if you don't mind me asking, how long did it take to receive your machine and was there any quality issues on the steel rails? I have left 3 messages and sent two emails just trying to get a few questions answered about the standard 2'x4' like yours.
    Sep 2007
    52
    Hello,
    I did not have to wait for it, because I went to pick it up...Mine is a 4x4 and what I call the rails are aluminum, but the part that everything moves on is steel...There are no quality issues at all..You may be missing a part or screw, but he takes care of that if you did..They are well built...........
  1. 1530 3 spindle cnc router wood cnc carving router from customer feedback
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 01-18-2020, 03:05 AM
  2. 1212 cnc router machine cheap modle wood carving router for advertising
    By BlueElephantCNC in forum News Announcements
    Last Post: 01-04-2020, 04:18 AM
