588,272 active members*
9,141 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Musical Instrument Design and Construction > How I use CNC in acoustic guitar building - Page 4
Page 4 of 4 234
Results 61 to 67 of 67
  1. #61
    Apr 2004
    326
    Re: How I use CNC in acoustic guitar building
    And finally, here it is together and ready for binding, armrest work, and lacquer. Will post finish pictures by the weekend.
  2. #62
    Apr 2004
    326
    Here's a few pics now that the lacquer is done. Was a good night. It took about 3 hours to level sand (600 grit) and then buff (med and super fine) the finish. I follow Robbie O'Briens finish schedule from his online course His schedule makes the final level sanding very easy.
    Here's a sample: https://www.youtube.com/watch?v=DITuYQeas5M
    Attachment 360988
    Attachment 360990
    Attachment 360992
    Attachment 360994
    Attachment 360996
    Attachment 360998
  3. #63
    Apr 2004
    326
    Pictures of #12 (mostly) finished. Just need to intonate the saddle. This was an amazing setup. The frets were so flat I only need to level 2 of them, then the initial setup
    came out perfect, no adjustment needed and 6/64" clearance at the 12th fret!
    I have no idea why the pictures are sideways.
    Attachment 361140
    Attachment 361142
    Attachment 361144
    Attachment 361146
    Attachment 361148
    Attachment 361150
    Attachment 361152
    Attachment 361154
    Attachment 361158
    Attachment 361156
  4. #64
    Apr 2004
    326
    Here's a video of the initial string-up/play. Note to aspiring builders - initial setup never sounds this good. This thing had perfect action by pure random chance.
    https://www.youtube.com/watch?v=dyU297z3hgE
  5. #65
    Feb 2006
    29
    That is a beautiful guitar! I love your process. I have created two electric guitars on my cnc mill, at work. A Les Paul, and PRS. I have a couple of questions for you. What do you use for a vacuum pump? What do you use, cutter wise, for making fret slots? Speed and feed settings?
  6. #66
    Apr 2004
    326
    Quote Originally Posted by Jer7440 View Post
    Thanks.
    For the pump, I use the same vacuum pump I got form joewoodworker.com. Meant for doing the vacuum bagging, I just put a different type of hose on it to push into the vacuum jigs.
    I use the fret cutter bits from precise bits.com ... BUT.... it is .025" bit, and I found that my slots are little too loose on the fit, so I've started using the .020" shell cutter bits to make they're snug. Maybe spindle runout causing that. I do .010" cut per pass, rather slow (whatever they're listed feed rates are). Running bout 12K rams IIRC.
  7. #67
    Jun 2017
    3
    Smile Re: How I use CNC in acoustic guitar building
    Love your designs!
Page 4 of 4 234
  1. My first CNC produced acoustic guitar jigs
    By Kosh in forum Musical Instrument Design and Construction
    Last Post: 07-14-2016, 06:11 PM
  2. Acoustic . electric/ Guitar Build
    By rusty999 in forum Musical Instrument Design and Construction
    Last Post: 01-17-2016, 01:23 AM
  3. Acoustic Guitar
    By HelicopterJohn in forum MetalWork Discussion
    Last Post: 03-18-2013, 12:37 PM
  4. Anyone made an acoustic guitar?
    By NeoMoses in forum Musical Instrument Design and Construction
    Last Post: 01-02-2007, 01:45 AM
  5. Acoustic Guitar Rosettes
    By jemmyell in forum Musical Instrument Design and Construction
    Last Post: 07-17-2003, 05:26 AM
