588,286 active members*
5,088 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Bridgeport / Romi Lathes > Help!! EZ path "Commanded x axis move too far minus"
Results 1 to 3 of 3
    Dec 2018
    9
    Hi, I have been running programs for the last 5 days on my 1998 EZ path S without any issues. But I accidentally used the "W SHFT" command and now it is not possible to run programs anymore. I am not even able to preview the programs on the display. I get the error message "Commanded x axis move too far minus". I have tried to move the crosslide to the home position (max X and max Z) and zeroing the w shift again, but still I get the same error message. Any ideas?
    Jun 2005
    1730
    Re: Help!! EZ path "Commanded x axis move too far minus"
    That button probably moved your work space coordinates. My guess would be to press again or a couple times. Test it after each press. Machines can have five or more defined work spaces
    Russ
    Mar 2009
    29
    I have an older EZ Path. I remember that error but not how to clear it. I think it has to do with you UCS (User coordinate System.) having been shifted when you hit the F1 or W Shift key. That W shift screen must have had a value in the fields that shifted your UCS. F2 gets me to the tool offsets page. That shows the UCS display. I don't know if any of this helps but.... good luck!
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. "Y minus" loses steps on accelleration
    By Mal Buckmaster in forum DNC Problems and Solutions
    Last Post: 06-08-2009, 12:56 PM
  3. PMC-ALARM 202 "Commanded Tool in Spindle"
    By moldmker in forum Mori Seiki Mills
    Last Post: 04-23-2009, 04:58 AM
  4. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
  5. ALARM!!! "Commanded X Axis move too far / Positive"
    By aimeahz in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2006, 11:51 PM
