588,337 active members*
4,948 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Tormach PathPilot™ > Can someone tell what is this message(alarm)
Results 1 to 16 of 16
    May 2008
    666
    I get this message when opening pathpilot. Could somebody tell me how to fix this,
    I tried so hard to have my programming computer to connect with pathpilot than I must have modified something important.
    Both computers are on the same Wi-Fi, pathpilot computer can go on the web, and it is connected. Internet led is green on the status page.
    I have shared folders on my computer but no luck so far..........
    Dec 2012
    390
    Re: Can someone tell what is this message(alarm)
    It kind of says in the error message what you need to do...
    The file dmrc in the user's home directory has the wrong permissions.
    What you need to do, is get to a command line (can't remember how to do that, but search this forum), cd to /home/operator (I think that is the correct user) and do chmod 644 dmrc
    May 2008
    666
    Thanks, will try.
    Mar 2009
    1982
    Are there some more alarms popping up if you just click on "OK" ?
    May 2008
    666
    Quote Originally Posted by Algirdas View Post
    No, I click OK and pathpilot start normally. My problem is I know nothing about linux. I try for quite some time to send my program to the lathe controller in the GCODE folder, but I can't.
    I can see the other computers on the network, but not the pathpilot controller. They all share the same SSID.
    Dec 2012
    390
    Quote Originally Posted by jeffrey001 View Post
    Seems samba (the service which lets Linux PCs show up in Windows network) isn't set up or running. Should be in the user manual how to set it up. I'm not near my machine, or even at home, so I can't check out how to do it.
    Mar 2009
    1982
    sometimes it is easier to set up the FAT32 formatted partition on Windows PC and share it on the network for Linux. Windows advices and docomentation are much more better than Linux jungle.
    May 2008
    666
    I'm waiting to receive an Ethernet switch and connect everything with Ethernet cable.
    Watched every video on this subject and every time it looks so easy.
    I was on Pathpilot this night and tried a ping to my IP4 address on one of my computer, and it can send and receive the data.
    May 2008
    666
    Why using FAT32 instead of NTSF partition, just curious to know. Jeff
    Jun 2005
    655
    Tormach PC or a home-brew? The Tormachs have been set up to expose network shares easily in my experience.
    All else fails in Windows you can put the IP address of PP in the file manager like so \\192.168.1.234 and see what it does
    May 2008
    666
    Quote Originally Posted by shred View Post
    The controller is from Tormach. It is at least 5 or 6 years old.
    From the terminal on Tormach controller, if I ping my programming computer, I can see it. It also works from my programming computer to the Tormach controller. I've installed an Ethernet switch and every computer is now connected with Cat6 cable.
    Jeff
    Nov 2022
    13
    It sounds like you have tried this already? I haven't done it but posting here in case you missed it.
    https://blog.tormach.com/connect-your-tormach-to-the-internet-ditch-flash-drives
    Mar 2009
    1982
    FAT32 is accessible from Linux by default. To access NTFS you my need some special setup at Linux side.
    May 2008
    666
    Thanks for the advice.
    Jun 2005
    655
    Jeff
    What happens when you try to open a file share from Windows using the IP address of the controller?
    Nov 2022
    13
    FWIW I have been struggling for a few days to access my machine and accessing via ip address worked like a charm.
  1. AMADA Alarm Message
    By fdv991 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-02-2020, 03:01 PM
  2. E STOP ALARM MESSAGE
    By CPatten in forum Bridgeport / Romi Lathes
    Last Post: 12-14-2015, 06:18 PM
  3. Alarm message
    By Sigma in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2008, 12:07 AM
  4. Alarm with no message
    By mr_electrician in forum Fanuc
    Last Post: 06-17-2008, 06:49 PM
  5. Alarm Message SV003
    By Grillen in forum Servo Drives
    Last Post: 05-06-2008, 01:16 PM
