588,328 active members*
4,304 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Engraving Machines > Modela MDX-15 woes - trying to get it to work
    Dec 2018
    7
    I have received this machine and I want to try and get it running.
    At present, I used a under powered adapter and the Power goes on and the lights turn on.
    When I press VIEW, it moves the plotter back and forth including the base plate.
    Pressing up and down does nothing.
    Is there a reset switch or a diagnostic mode I can go into to check if it is working properly for the motors?
    Nov 2013
    4607
    Re: Modela MDX-15 woes - trying to get it to work
    so have you downloaded the manual? It rather looks like its restricted to early version Windows, say Windows XP?
    Craig
    Dec 2018
    7
    I can get a machine running with XP, that is no problem - I will need to source a parallel/series port though. Anything I should look for in a serial port card?
    Also, I need to get a proper AC adapter for it. Right now I am using a 9V 600mA adapter I found - which I think is underpowered for the unit
    Dec 2018
    7
    I got it to work with an adapter and a serial port. I just need to know how to test it to make sure it is running properly. I would like to engrave something small, even if I don't put any wood in it, just watch to make sure it is running properly. Anyone have a tutorial on how to get started engraving? or even a project file, for something really small I can test?
  1. Roland Modela MDX-3/Picza PIX-3
    By Graeme G in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 04-05-2020, 03:32 PM
  2. G Code for Roland Modela MDX 15
    By lawmate in forum PCB milling
    Last Post: 02-02-2016, 10:54 PM
  3. For Sale: Roland Modela MDX-20
    By tonyturner5 in forum For Sale Only
    Last Post: 07-03-2014, 05:31 PM
  4. ROLAND MODELA MDX-15
    By EBOLEXX in forum Spanish
    Last Post: 05-02-2014, 03:52 PM
  5. roland modela mdx 15 serial cable
    By breazr in forum DNC Problems and Solutions
    Last Post: 07-26-2012, 01:25 PM
