Hello all,
I am drilling polycarbonate using a .027 dia. carbide drill in a Hydraulic holder, .530 Deep.
I am wanting the holes to have no internal burning.
I have used coolant , and moved to
Chilled air.
Any help on this would be GREAT!
Design. Make. Inspect.
Hello all,
Chilled air.
polycarbonate is a s***t to machine, its so heat sensitive it gums up tools in no time.
You will have to peck drill, I would suggest 0.050 per peck or less with a full retract. Whether you use coolant or air, it has to dislodge the chips from the flutes of the drill
otherwise those chips will go back down into the hole and wreck things.
Craig
Wow, .027" Diameter at .530" in Polycarbonate with no internal burning is not easy! Would you be using a Solid Carbide or Cobalt Drill right now? Carbide would be the way to go to reduce the heat if you can. I know there are options for coolant thru the shank to the tool, that would help reduce the heat generated and keep the internal burning from happening (if you would like info on this let me know).
Usually with Micro Drills we peck at 25%-50% of the tool diameter so I would try a peck of .007"-.014" and Craig is correct, you need a full retract or one within 0.5XD (.014") to make sure chips get out. If you are using carbide then RPM would be around 10,000 with a .0004"-.0008" IPR Freed Rate.
The chilled air makes a lot of sense and is really smarty, I just wonder if it would have the pressure to keep the part cool at .027" Diameter x .530" Depth. If not then the coolant thru the shank tool could be a good option.
Hopefully this helps!
Mike
www.toolhit.com
cant imagine there'd be such a thing as a through coolant drill of only 0.027" diameter. That would make a thin walled tube at best, and that fragile as to be useless.
I have and occasionally use 0.3mm drills (0.012") and I only ever plan to use them once, they are so fragile that you often break them before you get them fitted into the spindle!.
Craig
Sorry Craig, should have included an image to better show it! It is the Mikron Crazyflex Drill, they are coolant thru the shank and start at .0039" Diameter to .079" Diameter and are available in 20XD, 30XD and 50XD. With them you have to peck but the coolant thru the shank along with relieved neck allow coolant to get to the cutting edge to keep the part cool and help evacuate chips.
Thanks!
Mike
www.toolhit.com
though spindle running through the slits of an er collet should supply sufficient coolant for that kind of depth
I was imagining the coolant travelling right down the center of the drill to the tip.....but that would make fragile tools unusable. The coolant coming out of holes in the shank is the next
best thing. How much are they worth?
I find that if I need holes in plastic, I use acetal because it forms nice chips, that I can really only drill pilot holes (5mm deep or so) because the chips don't clear well enough. I will then drill the holes to the
correct depth with a regular HSS twist drill once the CNC phase is complete. I don't get any of the burning/melting/deformation with HSS, mainly because it is spinning so slowly by comparison to carbide drills
in my mill.
Craig
