588,487 active members*
5,255 visitors online*
Login Register
HEXAGON - Banner
HEXAGON Forum
Design. Make. Inspect.
G-REX > G-REX wiring - Page 2
Thread: G-REX wiring
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Nov 2007
    42
    Mark,
    Late getting back to me? I thank you for getting back to me at all.
    The top spindle speed as spec'd on their website is 4,500rpm unfortunately not having paid attention to what actual rpm i've used before i can't tell whether this is particularly high or not.
    I will probably try the G320 as you suggest simply because i already have it and see what it runs like. If it proves to be a problem i will investigate the other drives.
    As for software i am intending on running it with Mach3 as this seems to be the preferred software around here.
    Unfortunately Sydney is a long way from Perth so you'll have to be content with some pictures when i am underway.
    Lost Tourist
    Lost,
    When you get time for pic's send them to:
    mark dot holycross at yahoo dot com
    Mark
  2. #22
    May 2008
    5
    G100, Mach3 and Limit Switches Connections
    I am new to this setup, so i will highly appreciate if some will help.
    In Mach3 software, in “Ports and Pins”-->”Input Signals”, I have made configurations as described in the "manual of G100 for Mach3"
    X++ 17
    X- - 15
    X Home 17
    Y++ 17
    Y- - 15
    Y Home 17
    Z++ 17
    Z- - 15
    Z Home 17
    So if i have NC switches, shall I connect wire to “LIM” terminal then to NC switch and then to the GND available for each axis block on G100 terminals. I have also defined pin 15 in Mach3 software as X- -, so will I wire the pin 15 to the GND terminal labeled on G100 under “Digital Inputs”.
    I want to use five limit switches on my machine axes, for X axis and Y axis on both sides as . X++, X- -, Y++, Y- - and for Z axis only at Z+ side, I don’t want to use Z- -.
  3. #23
    Aug 2007
    10
    Shah,
    I'm probably not the best person to be commenting as i only just got around to connecting the motors the other night.
    But as i recently started understanding things for the limit switches yes you wire them between the LIM terminal for the axis and GND. (Remembering that you can wire both limit switches in series for a single axis if they are NC, in parallel if they are NO)
    I'm a little confused about the pinouts at the moment, I would have thought your X++ and X-- are wired in series and then wired to Pin 17 and similarly Y++ and Y-- to pin 18, Z++ to pin 19. I don't understand where pin 15 is. (but it is late and i'm not paying enough attention so it may be right in front of me)
    I'm not sure what your home switches are. Normally I think you would use one of the limit switches as your home, but if you are using seperate switches then you'll probably need to wire them to a non axis related digital input and code for them in Mach.
    Oh yeah and i should probably update the circuit drawing to include the ERR/RES as well. I'll do it later this week
    Lost Tourist
  4. #24
    Aug 2007
    10
    I'm close now.
    I successfully reloaded the firmware after installing the wrong one first and now Mach happily talks to the GRex and everything that moves moves as it should however i haven't figured out how to set up the spindle at the moment (step/dir drive) Anyone got any hints on this?
    Lost Tourist
  5. #25
    Nov 2007
    10
    Hello
    I do not know where to begin.
    Do not know at what Stepper motor Voltage to run.
    How much VA rating ring transformer to use.
    How many Amp transformer to use.
    How many transformers, each axis or one large transformer.
    Do i need optocouplers between stepper driver and G-Rex G100
    How to wire the Home sensors
    Spindle control etc.
    All with MACH
    I would be very grateful to hear from anyone willing to help with a wiring diagram.
    I can email all .pdf to components etc
    Stepper motors: Nema23 1.8
    BIPOLAR ONLY PARALLEL
    Current 4.2 A/Phase
    Resistance 0.7 +/-10% ohm/Phase
    Inductance 3.2 +/-20% mH/Phase
    Holding torque 300 N.cm Min
    Stepper Driver Card: CW250AC
    Home switches: Omron TL-Q5MC1-Z
    Variable speed drive: VFD015M
    Delta inverter 220v 1.5kw
    Many thanks
    Carl
Page 2 of 2 12
  1. need help wiring
    By dtman in forum Waterjet General Topics
    Last Post: 07-14-2020, 07:10 PM
  2. Wiring help.....
    By fineartlig in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2007, 05:21 PM
  3. Wiring help
    By watsonstudios in forum Automation Technology Products
    Last Post: 06-13-2007, 05:32 AM
  4. wiring it all together
    By russell in forum CNC Machine Related Electronics
    Last Post: 08-22-2006, 03:08 PM
  5. P5 Wiring
    By tintruder in forum Servo Drives
    Last Post: 02-03-2006, 06:13 PM
