Hello there.
I have a 1989 CS-42 machine with OTB controls. This machine has live tooling.
This is a Akebond built machine so I'm have trouble with Hardinge finding anything on it.
It has a weird serial number for them to look up. 4600015
The problem is when I use the M codes for live tooling it comes up with error invalid M-code Programmed.
My question is does anyone know the Parameters for this machine that controls this option?
We bought this used several years ago and just now are wanting to use the Live tooling on it.
All M commands for live tooling come up with the same error.
The funny thing is that the tooling runs and you can change the surface speed.
The part that doesn't work is the cooling doesn't turn one with the M53 command.
So I tried M51 with no cooling and it still comes up with the same error.
The stop command also produces the error.
Thank you for your help in advance.
Darrin
