INDEX
2661
INDEX
2661
One Turret, Two Drives – Zero Time Loss
The newly introduced sliding headstock automatic lathe TRAUB TNL32 has been extended by another variant. In this design the counter spindle is mounted on a separate cross-slide with X- and Z-axes. Rear end machining is carried out by one of the two X/Y/Z turrets. The two tool carriers can be used both on the main spindle and counter spindle. This further development extends the machining spectrum to workpieces with lengths over 300 mm, which can be removed afterwards through the counter spindle and placed onto a conveyor belt. The major mechanical and control features of this machine variant are identical with the familiar TNL32 and will set new standards on the market for sliding/fixed headstock machining, including an even larger work space, ten-station turrets, higher performance data and, as its highlight, the so-called “dual drive” – a turret, with two integrated drivetrains that considerably reduces secondary processing times.
The TNL32 sliding/fixed headstock automatic lathe
Simple change-over between fixed and sliding headstock turning
It takes just a few steps to convert the lathe with sliding headstock to fixed headstock turning mode and vice versa. The extremely long Z-travel of the headstock ensures proper positioning of the main spindle, either for sliding headstock turning or fixed headstock turning.
Generous work area with innovative inner values
The most noticeable feature of the TNL32 series is the considerably enlarged, generous, and user-friendly work area. The TNL32 has a ten-station turret. Turret indexing is performed using an NC rotary axis that controls movement via an internally meshing planetary gear. This allows the turret to be indexed to any preferred position without a mechanical locking mechanism being necessary. The free positioning of the turret makes multiple-tool assignment possible on each station so that the top tool carrier can be equipped with up to 30 tools. Since mechanical locking is no longer necessary, chip-to-chip times of 0.3 sec are realized.
The innovative highlight is the “Dual Drive” – two drives integrated into one turret. This smart and patented drive solution with two separate drivetrains in one turret reduces the auxiliary processing times and also keeps the cycle times to a minimum. The ingeniously simple idea: While one tool is in use, the tool intended for the next work step can be accelerated up to the desired speed during main time and is immediately available at full speed after the turret indexing operation. Jerky accelerations and delays that were previously unavoidable when reducing auxiliary processing times are now a thing of the past.
In addition, the user benefits specifically from the fact that tool holder wear is drastically reduced due to the low acceleration values. The chip-to-chip times in the case of live tools are under 0.3 seconds.
Interaction of systems: Main spindle, top turret, back working attachment
 and counter spindle with integrated bottom turret
Improved tool mountings
The tool holder product line is completely compatible with the TNL18 series, only the drive wheels in the live tool holders have to be replaced if necessary. Both variants make use of the new TRAUB compact shank system: an improved system for highprecision mounting of tool holders in the turret. The tool holders are seated deeper in the turret, which results in less leverage effect and, thus, higher stiffness. For live tool holders, the large shaft diameter allows for the installation of roller bearings with large diameters. A quick-change system enables high-precision, smooth exchange of tools without removing the tool holder. The compact shank system verifiably increases the tool life and also contributes to improved surface quality.
For complete and complex machining operations
Simultaneous machining with multiple tools ensures high productivity levels with both machines. In this process, up to three tools are used simultaneously on two spindles. The TNL32P production machine differs from the TNL32 variant in that the Y-axis motion of the upper turret is affected by interpolation of the X/C/H axes. This allows milling contours to be created by entering values in the standard Cartesian X/Y/Z coordinate system. Reliable off-center, parallel axial drilling is thus also possible using this method. A powerful, swiveling counter spindle is fitted onto an X/Y/Z cross-slide that simultaneously also carries the lower tool turret. This slide is characterized by large axis travel distances. The travel for three-axis rear end machining, even for geometrically complex workpieces, can be freely configured. In this counter spindle version, the machine has always been equipped with a durable back working attachment.
It accommodates 8 tool holders of which three can be live. A total of 4 stations are provided with an internal coolant supply. Each station can be controlled individually so that cutting oil is supplied selectively. The large travel distances of the counter spindles enable stations to be occupied by more than one tool (e.g., dual drill holder). Another innovation is the refined drive scheme for the utilized tool holders that deliver either high speeds or high torques. The integrated workpiece removal allows the workpiece to be rinsed out or, optionally, picked up and deposited for positioning purposes.
Alternatively, the TNL32 can now be provided with an autonomous counter spindle. A counter spindle with performance data identical to those of the main spindle is mounted on a X/Z cross-slide. As a new feature, parts with a length of >300 mm and a diameter up to 30 mm can now be discharged through the counter spindle.
Tried-and-tested control family
The TNL32 is equipped with the TRAUB TX8i-s control and the TX8i-p for the TNL32P. Both controls are based on the CNC control from a worldwide leading control manufacturer while the user interface software – like all models developed in the last 30 years – is a one hundred percent TRAUB development. The benefits are obvious: Customers need not rely on standardized software products; rather customer and application needs can be implemented and integrated optimally into the development. Of course, the control is compatible with all previous TRAUB controls so that existing programs can be used.
Features that speak in favor of the control:
  • Reduced set-up time due to higher NC performance,
  • Two-way programming, optimization and simulation in interactive or in NC mode possible, (TX8i-s integrated, TX8i-p via external CNC client application) Error avoidance and setup time reduction through object-oriented interactive guidance,
  • sensitive tool break and wear monitoring,
  • compatible with all previous TRAUB controls,
  • high availability
  • optimal support because the machine, control and drive are from a single source.
Small footprint and easy access
The vertical machine bed design results not only in a favorable chip flow but also an extremely compact footprint. This is also made possible by integrating the control cabinet in the upper part of the machine. This enables space-saving integration of the automatic lathe into existing machine groups. The work area is easily accessed by the operator through its remarkably high and wide sliding door. This provides a lot of room for setup and changeover activities. A generously dimensioned inspection window allows the operator to keep a close eye on the machining process. Another plus: For servicing, only a few manipulations are needed to remove the back cover to allow full access to the mechanical assemblies. The hydraulic and pneumatic components are also arranged with full accessibility to the rear of the machine and can be easily checked at a glance.
Target group of the new TNL32 sliding/fixed headstock automatic lathe with ten-station turret and “dual drive” includes the entire machine manufacturing industry, automotive and hydraulics industry as well as medical technology. Its strengths are utilized primarily where both simple, small and geometrically highly complex parts from all industries, from medical technology to hydraulics and the automobile industry, are machined with a maximum bar clearance of 32 mm.
Responsible for the content of this press release: INDEX-Werke GmbH & Co. KG Hahn & Tessky
