Krebs & Riedel Schleifscheibenfabrik
27
27
Double disc grinding with planetary kinematics / face grinding / fine grinding | KREBS & RIEDEL
krebs-riedel news Image
Double disc grinding wheels with a diameter of 1500 mm
High performance DIA & CBN double disc grinding wheels for face and finegrinding Krebs & Riedel has many years of experience and references in double disc grinding. We offer tailor-made solutions for a wide range of applications, machines and workpieces in the area of face and finegrinding. Krebs & Riedel manufactures double disc grinding wheels up to 1500 mm outer diameter made of DIA and CBN in vitrified bond for the effective creation of flat surfaces with a high surface quality and shape tolerance for a wide range of different materials. The range includes grinding tools in different segmentation for single and double disc grinding machines with and without planetary kinematics. Compared to other systems, the vitrified bond system by Krebs & Riedel allows the production of very free cutting and porous coating structures. This results in a significant increase in productivity.
One system for tailored solutions
In addition to an intensive process analysis, we supply you with grinding, dressing and sharpening tools that are tailored to your production processes and your requirements.
• AL2O3 white, AL2O3 pink and SiC
• From 100 mm to 600 mm ring diameter
• Grain sizes from 80 to 600 mesh
• Fast delivery from stock possible
• Two layer design as an option
Your advantages
• Many years of experience and strong references
• Bespoke solutions with quality tools
• Pellet dimensions possible from 12 to 30 mm
• Solutions for roughing applications with high stock removal rates
• Pre- and finish-grinding with one machine concept
• Customer service and application support worldwide
• Fast delivery times and flexibility
• All products are „Made in Germany“
• Highest precision and excellent tool life
• Finest workpiece surface qualities
• Disc diameters up to 1500 mm
• Continuous development of specifications
Our service
• Selection of the optimal specification
• Pre-tests with own laboratory machine minimizes risk
• Production of customer specific grinding tool type
• Recommendation of the appropriate dressing strategy, process parameters and cooling lubricants
• Coordination & solution for the specific application
• Dilligent process documentation
• Continuous optimisation
• Application-oriented usertraining
• Repair of segments / replacement
• Recoating of base bodies
• Close cooperation with machine manufacturers
Please check out our new products at the GrindingHub 2024
Hall 7 booth 7A35
GmbH & Co. KG
Bremer Str. 44
34385 Bad Karlshafen
Tel.: +49 5672 1840
E-Mail: [email protected]
Web: https://www.krebs-riedel.de/planseitenschleifen/index.html
Responsible for the content of this press release: Krebs & Riedel Schleifscheibenfabrik GmbH & Co. KG
Your message
