Liebherr-Verzahntechnik
245
245
Process reliability from automation
liebherr-verzahntechnik news Image
A range of different materials and methods are applied in dosing and adhesive bonding applications for battery pack assembly. Applying heat-conducting paste in the battery tray and sealing the battery pack cover demands complete process reliability – any rejects at this stage become expensive. At the test facilities in the Kempten Tech Center, Liebherr-Verzahntechnik GmbH tests the automation for adhesive bonding and dosing applications and, from a single source, offers customer-specific applications providing process reliability.
Dosing occurs at two points in battery pack assembly. Firstly, a heat-conducting paste – the gap filler – is applied to the base of the battery tray before inserting the battery modules in order to ensure heat dissipation. In the ‘sealing’ stage, the battery system housing is finally sealed. Precision and process reliability are essential as errors at these points can have serious consequences.
Thermal management
In high-voltage battery systems, thermal management has a critical role to play in extending the service life of the batteries and ensuring their safety and efficiency. Without effective heat dissipation, the temperature inside the battery pack can rise uncontrollably. Overheating can trigger thermal runaway resulting in fires and explosions. The increased operating temperature can also accelerate battery cell aging and shorten the service life of the battery pack.
Gap filler or thermal interface materials (TIMs) therefore ensure heat is dissipated from the battery modules and cells into the cooling system. Its application in liquid form achieves an optimal coating and improved thermal connection between the heat source and heat sink. Gap fillers or TIMs must be applied precisely and with no formation of air pockets. This is the only way to ensure effective thermal transfer in order that the electronics and battery cells can function safely and in a durable manner within the optimum temperature range.
Sealing the housing
High-voltage batteries must be completely sealed to ensure their performance, durability and safety and to protect them from environmental influences. Moisture, dirt and contaminants can impair the batteries and shorten their service lives. Complete sealing also prevents environmentally harmful electrolytes from escaping. Housing seals can also be applied in the form of hot glues – in most cases hot butyl. These also provide a quick, efficient and complete seal with high temperature resistance on uneven surfaces.
Challenges in the process
When dosing, exact lines of liquid adhesive and clean bead transitions are vital for ensuring quality. Irregularities in the dosing bead can impair the performance of the seal. When applying material, the challenge is therefore generally to maintain control via the dosing parameters. This ensures an even application throughout the entire dosing process.
Key aspects of dosing
Liquid dosing using one- or two-component media is a delicate process subject to external influences such as temperature deviations. The different material properties in terms of viscosity and curing characteristics must be taken into account from removal to mixing at the dispenser and when calculating the bead paths. When applying the heat-conducting paste on the base of the battery tray, the optimal application pattern is also important for ensuring sufficient coating of the base, preventing air pockets and also for optimal consumption of the expensive material. Pre-treatment methods and activation of surfaces also contribute to optimal adhesion.
... read more here!
Responsible for the content of this press release: Liebherr-Verzahntechnik GmbH Verzahntechnik und Automationssysteme
