586,067 active members*
4,790 visitors online*
Login Register
Maquinaria Colás
Top quality used machine tools
Contact
Maquinaria Colás, S.L.
Ctra. Castellón km 5.2 Vía de Servicio
50720 Zaragoza
Spain
+34 976500624
+34 976500630
Route planner
Route planner
Mori Seiki NT 4250-DCG 1500S CNC Lathe
CNC lathes (4 or more axes)
DMG DMU 160P 5 Axis Machining Center
Doosan Puma 3100L CNC Lathe
CNC-lathes (2-axes)
Correa Anayak VH Plus-3000 Bed Type Milling Machine
Bed milling machines (moving table)
Ona AE-400 Wire EDM
Ona AE-400 Wire EDM
Wire spark erosion machines
ONA HS 400 Die-Sinking EDM
Die-sinking spark erosion machines
ONA HS 600 Die-Sinking EDM
ONA QX8 B1L Die-Sinking EDM
Awea VP 2012  Brige Type Milling Machine
Portal & Gantry milling machines
Nicolás Correa CF22/20 Bed Type Milling Machine
Correa CF17D  Bed Type Milling Machine
Correa FP 30/30 ATC Bridge Type Milling Machine
Mazak FJV 35 60 Vertical Machining Center
Machining Centers (Vertical)
Mazak Nexus 510 C Vertical Machining Center
Mazak VTC 800/20SR Vertical Machining Center
Service Spectrum: Represented in 3 categories
Services
Second-hand machine tools
Second-hand machine tools, metal cutting
Second-hand machine tools, metal forming
Other Used equipment
About us
Maquinaria Colás  Used Machine Tools and New Machine Tools
Maquinaria Colás have been suppliers of quality new industrial machinery and used machine tools throughout Spain and internationally for almost 35 years. With substantial investment in metalworking machinery stock , we are able to supply you with the used machine tools most suited to your needs. We own a 5000 square meters warehouse with hundreds of machines where you will be able to find the industral machinery you are looking for.
If we cannot supply the machinery you are looking for from our stock, we are in a position to locate the exact same machine you require as a result of our established international contact network.
Our main activities are:
Visit us on our
Social Networks:
  Used Machines
Mori Seiki
Asking price
