587,227 active members*
3,819 visitors online*
Login Register
Mastercam Forum
Shaping the future of manufacturing
Autodesk CAM > Fusion 360 Cam seems to make me use smaller bits then I would think - Page 2
Page 2 of 2 12
Results 21 to 36 of 36
  1. #21
    Aug 2016
    185
    Re: Fusion 360 Cam seems to make me use smaller bits then I would think
    I will try and do a predrill hole. But everything looks correct...
    Sent from my XT1635-01 using Tapatalk
  2. #22
    Oct 2010
    171
    If you're so inclined, send me your f3d model via PM and I'll take a look at it.
  3. #23
    Aug 2016
    185
    Quote Originally Posted by precisionmetal View Post
    How do you want me to send it?
  4. #24
    Oct 2010
    171
    sent you private msg
  5. #25
    Aug 2016
    185
    I emailed you back. I will export the file later today as I am not home.
    So you have cut an 80 AR10? Where did you get your CAD?
    What kind of CNC you using
  6. #26
    Aug 2016
    185
    Quote Originally Posted by truckeic View Post
    Sent you the file.. thanks
  7. #27
    Oct 2010
    171
    On the 2nd tab for your adaptive tool path, reduce minimum cutting radius from .0375" to .010" and you should be good to go.
  8. #28
    Aug 2016
    185
    So I can learn.. what is that setting.
    I will get back on fusion tonight.
  9. #29
    Oct 2010
    171
    The dimension between the inside walls you are machining is .438".
    You're using a .375" end mill. Minimum radius was set at .0375", so double that is .075".
    Add .075" to .375" and you have .450", which can't "fit" between the walls that are .438" apart.
    Don't be tempted to just set this to zero or a very small number.... a machine needs to "move" when it's cutting an inside radius, and keeping this value at a realistic number is a good idea. As you can probably see, if you were "leaving stock" for a final/profile cleanup pass, it would be difficult to do this roughing with a 3/8" end mill. Might need to go to something just a bit smaller in that hypothetical scenario.
    PM
  10. #30
    Aug 2016
    185
    PM
    Ok so I just tried it and it worked.. so min radius from the help menu in Fusion says that it will leave sharp edges.
    So is that how to figure it.. if it was set to .0375 you double that number and add to the cutter?
    Did you run my CAM?
    Maybe it is not really doing this, but the backend of that pocket (where the cutter was not going before we changed that min radius) looks like there is a small area it's not cutting..
    Am I just seeing things?
    Thanks for the help!
  11. #31
    Oct 2010
    171
    It looks OK on my computer, though if it was me, I'd probably put a piece of machinable wax in the machine and run your tool paths on an expendable piece of material before going after the real part.
    Personally I'd approach this a bit differently: drill a series of holes down the center to get the majority of the material out, then remove the balance of the material fairly aggressively but leave maybe .010" stock on the walls, then finish up with a profile pass.
    Is your blank 6061 or 7075? All those little step-downs will be hard on the corners of that 3/8" end mill. I rarely do any roughing with an end mill that doesn't have a corner radius, then if necessary, I'll make a final pass on the floor with a square-corner end mill.
  12. #32
    Aug 2016
    185
    I wish I knew more.. the reason for the small cuts is because I have a X2 mill. Small Mill.
    So you say radius.. ball endmill or what?
  13. #33
    Oct 2010
    171
    No no... not a ball end mill, just one with a bit of a corner radius. Typically called a "bull nose", but actually all that's required is a .005" or .010" corner radius and they hold up WAY better. :-)
  14. #34
    Aug 2016
    185
    Are we talking radius on the nose of the endmill?
  15. #35
    Oct 2010
    171
    Corner radius:
  16. #36
    Aug 2016
    185
    Thanks for everyone that posted and helped I truly appreciate it!
Page 2 of 2 12
  1. Help me make a clone of my Fusion 640M Hard Drive
    By camarogod98 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-14-2018, 07:55 AM
  2. Replies: 0
    Last Post: 08-31-2014, 06:38 PM
  3. Replies: 0
    Last Post: 08-31-2014, 02:19 AM
  4. how to make the drawing smaller
    By cob in forum Mastercam
    Last Post: 11-20-2008, 04:36 AM
  5. You CAN make holes smaller...
    By InspirationTool in forum MetalWork Discussion
    Last Post: 11-22-2005, 04:02 AM
