586,080 active members*
3,992 visitors online*
Login Register
Mastercam Forum
Shaping the future of manufacturing
CNC Wire Foam Cutter Machines > NEW BUILD Hot wire CNC Foam Cutter "Desktop" size
Results 1 to 6 of 6
    Nov 2011
    107
    I have just made a small size foam cutter, so far, so good. It Is powered by the Smoothieboard, it uses extruded aluminum, some 3D printered parts. Right now im trying to add a thermocouple to improve the cutting temp along with the cutting speed, any suggestions??
    https://youtu.be/AKgKzSsWntw
    Attachment 362070
    Attachment 362072
    Attachment 362066
    Attachment 362068
    Mar 2011
    4
    Re: NEW BUILD Hot wire CNC Foam Cutter "Desktop" size
    Nice! This looks very impressive.
    Mar 2011
    4
    Error in posting
    Feb 2007
    191
    Hello, very nice Machine.
    Iam begginin to build mine
    What CAM software are you using for letters?
    Are you using Mach 3?
    Thanks for your reply
    Nov 2019
    5
    Hi!
    Very nice machine, can you share a little bit information about heating the wire, how you control it. Where you buy this "brackets" that slide up /down and hold the wire, my guess 3D printing?
    May 2005
    73
    what software are you using to run it
    have a look her https://www.rcgroups.com/forums/show...plete-Solution
    lots of info there
  1. Replies: 7
    Last Post: 01-10-2015, 01:40 PM
  2. Replies: 0
    Last Post: 11-10-2014, 04:26 PM
  3. 24"X, 18"Y, 3"Z Steel Frame Desktop Machine
    By TLHarrell in forum DIY CNC Router Table Machines
    Last Post: 06-16-2009, 06:33 AM
  4. Wire for foam Cutting "EdgeSweets" machine
    By singerdon49 in forum Employment Opportunity
    Last Post: 12-29-2008, 03:12 PM
