586,100 active members*
2,769 visitors online*
Login Register
Mastercam Forum
Shaping the future of manufacturing
Haas Visual Quick Code > Custom VPS templates (Visual Programming System)
Results 1 to 15 of 15
    Jun 2013
    4
    I bought HAAS VF-2SS and I'm trying to make custom VPS template for easy and faster programming.
    Is there a manual/tutorial for using excel template 'VPS Template.xls' witch already came with machine ?
    For now I figure out how to put images, how to write code but I cannot figure how to get variables from machine, how to calculate variables etc.
    Maybe someone know how to download existing VPS templates to PC/USB?
    Jun 2018
    Did you ever figure this out?
    May 2006
    803
    Re: Custom VPS templates (Visual Programming System)
    I would like to hear more about this thread........
    Sounds like you want
    " I See, therefore a system can convert it to point-to-point G code and make what i envision"
    I have been doing this for 40 years now. somebody has to do it .....
    Been doing this too long
    Dec 2018
    4
    I can't get an existing VPS to a PC but i have made some custom Templates for me.
    what do you want to do? Maybe i can help you
    Hello,
    I know this is an old thread but i'm really interested in programming my own vps codes.
    We have a new Haas VF2-SS where I also found the template. On my own I found out how to make some simple vps programs with variables.
    Does anyone have more documentation around this subject? How to program the vps like Renishaw/haas own programs?
    Jun 2015
    4154
    hy alex, i don't have experience with haas, but i can help you with general informations, remote conversationals, etc
    haas renishaw vps at 1:25 in here ( if you wish, contact the youtube user for specifics ) :
    Aug 2007
    414
    Hello, I also played a bit with the template.xml. Here is an example of a position macro with max. 5 positions.
    The only thing I found was the template stored in the machine but I have no idea how to use the said template. If someone knows how to use the said template I'd be very grateful, I have a couple of different VPS templates I'd like to create.
    Nov 2012
    7
    Quote Originally Posted by eckitsch View Post
    you can upload the file again ?
    Aug 2007
    414
    To use the VPS template, you have to copy it from the machine to the PC and open it with Excel.
    Here is the example from the picture. Correct the file extension to .XML
    Makro_Einzel.txt
    May 2020
    Any update on this? We have gotten our VPS program to work, but not the images...
    Aug 2007
    414
    In the directory with the macro, a subdirectory for the images.
    Attention! A dot in front of the name of the subdirectory hides the directory on the machine. Then you can no longer get to the pictures. At least I didn't make it.
    Aug 2007
    414
    Apr 2021
    Can you send it again for me. And is your template tested and work?
    Jan 2023
    Any way to make use of optional parameters? I know that macros with #0 are ignored, but that's not works there — I've tried ::MY_OPTIONAL_VAR:: EQ ##0##, but that's not working; and $$ syntax too. Creating lot of gcode variants is not a way.
  1. Custom CAM CNC Line Programming
    By KH0UJ in forum DIY CNC Router Table Machines
    Last Post: 08-29-2019, 01:09 PM
  2. Replies: 0
    Last Post: 02-29-2016, 09:13 AM
  3. Custom Macro B programming
    By jHMANVF4 in forum MetalWork Discussion
    Last Post: 11-27-2013, 03:22 PM
  4. custom tool / programming question
    By riverracer in forum Mastercam
    Last Post: 10-16-2010, 11:48 PM
  5. Custom Macro Programming
    By TomL21 in forum Fanuc
    Last Post: 12-09-2008, 05:20 PM
