586,108 active members*
3,088 visitors online*
Login Register
Mastercam Forum
Shaping the future of manufacturing
Mach Software (ArtSoft software) > Mach 3 not running code
Results 1 to 1 of 1
    Aug 2022
    3
    HELP1! I have purchased received and assembled a Queenant Pro V 1015.
    I purchased with assembled controller for usb mach 3 .
    Bought Mach 3 software installed on 64 bit computer running windows 10.
    Fired up system installed driver for usb control card.
    System will jog at any speed I enter.
    When try to run gcode program it runs thru first few lines of code then starts running very erratic.
    Alls axis will move very rapidly a few mm. Its to take 5-6 seconds to move again. Continues to do this until reaches the location in the gcode.
    Never continues to run thru gcode to end.
    I have tried various small gcode programs they all respond the same.
    Nov 2013
    4376
    Re: Mach 3 not running code
    it rather sounds like a 'Run out of Data' problem and the motion controller is behaving erratically.
    I don not use nor do I trust cheap Chinese USB motion boards. I use an Ethernet SmoothStepper and Mach4 and have done for 8.5 years.
    Craig
    Aug 2005
    1094
    Is the licence valid?
    There are a number of counterfeit licenses being sold by Asian machine suppliers. Mach3 is able to detect some of these.
    If it is a valid license it could be a motion controller issue as Craig suggests.
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Aug 2022
    3
    I bought Mach 3 from Artsoft
    Aug 2005
    1094
    You can take that off the list of possible sources of the problem.
    It could be the configuration. Did you get a Mach3 plugin and profile file from the supplier of the motion controller?
    Cheers
    Peter
