586,076 active members*
3,893 visitors online*
Login Register
Mastercam Forum
Shaping the future of manufacturing
SolidCAM for SolidWorks and SolidCAM for Inventor > MAHO 432 Post Processor
Results 1 to 9 of 9
    Oct 2008
    23
    Hi, I'm using SolidCam to create the Gcode for my machine.... with a MAHO 432 controller.
    There is only the mac file in the installation folder but when I try to use SolidCam the drilling cicle write some error....
    But there isn't the GPP file for the machine parameter....
    There is a solution for my PROBLEM???
    Nov 2006
    4
    Solid cam 432 postprocessor
    Hello Micktat,
    I'm looking for a Solid cam postprocessor for the Philips 432 controller.
    Is it possible tat you send is by e-mail to me?
    Did you fin a solution for the drilling cycle
    Maybe I can look how to solve the drilling cycle problem.
    Kind regards, Desmo special
    Oct 2008
    23
    MAHO 432
    Hi, I'm using SOLIDCAM 2007, It has a "non-perfect" post for MAHO 432 but I can work with it...
    For the drilling cicle I rewrite in the right mode the GCODE....
    I can send to you the MAC file that the SC2007 use for GCODE, but for the newest it don't work... is it necessary the GPP and I haven't it...
    Feb 2012
    Hello,
    I seek a SolidCAM post-processor for a Deckel Maho DMU 60E with Heidenhain control MillPlus V321.
    I would be grateful if someone could e-mailed to:
    [email protected]
    Greetings from Germany
    sven
    Oct 2009
    3
    Hi;
    I am trying to find the PLC for Deckel Maho MH1000C , CNC 432 Series 480.
    If you happen to come across it I appreciate it if you could e mail it to me
    [email protected]
    Jul 2012
    Pls, help
    I need post fo Maho 432 SolidCAm pls help
    Feb 2011
    252
    I can write a postprocessor for you?
    [email protected]
    greeting
    Re: MAHO 432 Post Processor
    i need post processor philips 432 MAHO but for solidcam ...please help me
    Feb 2024
    Buongiorno,
    avrei bisogno del Post processor per il software ZW3D, controller Philips 432, per una maho MH800E.
    Grazie
    _____________________
    Good morning,
    I would need the Post processor for the ZW3D software, Philips 432 controller, for a maho MH800E.
    Thank you
  1. Deckel Maho 63V Post
    By louorfran in forum Surfcam
    Last Post: 04-14-2014, 04:21 PM
  2. DMG Deckel Maho Post
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-24-2014, 03:05 PM
  3. Need Maho 432 post
    By rroberts in forum EdgeCam
    Last Post: 11-23-2010, 12:56 PM
  4. Mastercam Post processor for Maho 700c with Philips cnc 432
    By Dirkos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-20-2007, 04:18 PM
