586,357 active members*
3,768 visitors online*
Login Register
RENISHAW Forum
Grinding > Harig 6x12 hand feed grinder
Results 1 to 3 of 3
    Aug 2008
    406
    I want to replace my spindle bearings . I know don't do it .But I have a plan . Taking it apart no problem. Re-assembly will be done inside a large plastic bag . I will put the spindle shaft in the freezer over night . I will put a cleaned bearing cartridge in a plastic bag .in the sun .The Pre load is accomplished by wavy washers . The nut is tightened against a shoulder .I have been told that over 400 people have done it themselves .As long as I wear gloves, align the marks correctly keep everything super clean use lint free wipes .I should not have problem . My question is the original bearing are Barden's 205 dplx & 204h angular contact bearings class p7 . I would like to use Nachi 7205 cy dup4 same dimensions and are class 7 bearing for half the price. What I am looking for is anyone that has re-done a Haig spindle . Thank you all.
    Jan 2013
    474
    Quote Originally Posted by gabedrummin View Post
    Should be fine, keep everything super clean, wash the bearings out with acetone and use Kluber NBU15 high speed grease (if greased). Rule of thumb is to,1/3rd fill the bearings if you don't know how much.
    Aug 2008
    406
    Re: Harig 6x12 hand feed grinder
    I was thinking the bearings should be installed like this ?Click image for larger version.
  1. Give me a hand for Circular Saw Grinder
    By agelkom in forum Uncategorised CAM Discussion
    Last Post: 08-28-2021, 11:02 AM
  2. Harig 612 grinder info
    By vpmachine in forum Uncategorised MetalWorking Machines
    Last Post: 06-16-2011, 05:33 AM
  3. Bp Harig Ez-Surf grinder manual
    By jketcham in forum Bridgeport / Hardinge Mills
    Last Post: 05-11-2008, 10:42 PM
