587,786 active members*
2,350 visitors online*
Login Register
Siemens Digital Industries Software Forum
Where today meets tomorrow.
Uncategorised CAM Discussion > What software do I need to create these lips??
Results 1 to 1 of 1
    Apr 2024
    HI CNC Legends,
    I've seen folks selling DXF files on Etsy like the below and would like to learn how these are created as I have some ideas of my own I would like to make for personal use. Can anyone please help with how and what software I would need to create a file I could cut out on my hobby cnc.
    Here is the link to the item mentioned above:
    https://www.etsy.com/au/listing/1403...BoC9kYQAvD_BwE
    Any help would be much appreciated.
    Apr 2004
    5752
    Re: What software do I need to create these lips??
    First you'd make a 3D model of the lips. Then you'd intersect it with a series of evenly-spaced planes, generate curves at the intersections and save them as DXF. Then you'd create toolpaths from the DXF curves in a CAM program and nest them to cut them most efficiently out of a sheet of material. You could do the CAD work with MOI (Moment of Inspiration) https://computersculpture.com/moi/ and the CAM part with DeskProto. https://computersculpture.com/deskproto . Of course, there are lots of other programs that could also do this.
    Andrew Werby
    Website
    Apr 2022
    140
    You can do slicing in Vectric and create a tool path or save in DFX.
