587,531 active members*
3,549 visitors online*
Login Register
Siemens Digital Industries Software Forum
Where today meets tomorrow.
Uncategorised MetalWorking Machines > Machine pitch error compensation
Results 1 to 7 of 7
    Mar 2006
    14
    Hello
    If there any one related to pitch error compensation of machines.
    I have got a problem while compensating a milling machine having Delta controller that one axis is compensated but the other two axes are not responding to compensation. What might be the problem?
    Mar 2006
    34
    which procedure u use by manually through controler
    or through computer?
    Feb 2004
    813
    (wrong)
    Mar 2006
    34
    what wrong Stevie?
    Mar 2006
    14
    compensation prb
    hello
    i was trying to compensate the machine Manually through controller. i can send you complete details of controller and its parameters.
    Feb 2004
    813
    this is not a project; it's a general question that should be in the general forum for cnc machining
    Mar 2006
    34
    ok
    my mail id is [email protected] send me which values u r putting in controler and how i think u r doing same in all axis
    but some code also change according to axis
