Configuring a Parker Gemini GV-U12E servo controller
I have a Gemini GV-U12E that I am trying to set up with Chinese BLDC. Its a 2.2kw (3hp) motor 4 pole with 3 hall sensors (no separate encoder) basically like the one that is sold here;
CNC4PC
I have it running open loop in DMODE13 at 1 rps, but when I try to run it in step/dir (DMODE6) from Mach3 it doesn’t turn and eventually I get a position error.
I have checked the Hall wiring and THALL reports the correct order. I am guessing that I have the configuration parameters for the Hall sensors screwed up.
Has anyone successfully set up one of the motors with this drive?
Robi
Tinmuk
Any problem can be solved by the proper application of heat!
