Hi! from Greece...
First of All sorry for bad My English.
I m 35 years old
Job: Art Director SonyBmg Greece
I m An expert on Graphic Arts so if you have any Q about Print, Colour theory, Photoshop, QuarkXress, Adobe Illustrator you can ask anytime....
I want to build A CNC machine to use it for doming decals
You can see this video: http://www.color-dec.com/doming500W.mov
Or Here
http://developmentassociatesinc.com/scriptxyz.htm
http://www.liquidcontrol.com/pdf/automation/c500.pdf
http://domeit.com/
http://www.efd-inc.com/xyz/index.html
I want to build A XYZ machine for doming scripting
Doming Scripting
Doming: Applying a clear doming material
(urethane & epoxy) to the surface of labels, nameplates or decals for the purpose of creating a clear raised (“domed”) surface. Used to enhance and protect the appearance of these products.
Scripting: An automated doming process using XYZ motion to traverse scripted products.
I Almost finished the hydraulic part a precision metering system for two component.
I have to mix in Ratio 1:1 two parts and the mixed fluid has to be applied under (0.5 -1 bar) pressure on decals or stickers by the dispense valve
I need at least 50cm X70cm work area...
So the Questions:
What table do you thing I need?
I look to buy the Janome JR2400N
http://www.scara-robots.com/desktop_specifications.htm
But it Cost 13.000 Euro (about 16.000$) its too exp for me...!!!
George Toubalis
Greece Athens
