586,121 active members*
3,012 visitors online*
Login Register
Siemens Digital Industries Software Forum
Where today meets tomorrow.
CNC Tooling > Which is your favorite end mill for Alloy?
    Jun 2013
    443
    I've been using Chinese endmills off Aliexpress for a while now with great results. These for the 4mm single flute hole making up to 10mm two flute extra long with a flute length of 45mm. All ok. Cheap.
    I also have been using some local supplied 8mm to 14mm 2 flute end mills. The 14mm I think is about my limit, any larger my machine might not be rigid enough. The 8mm 2 flute I have, has a 15mm flute length, with a wasted portion of the shank up to 50mm good for a deep cut but tends to sing a bit giving a slightly chattering finish on the side. If it was 10mm might be an improvement but I was just quoted NZ$150.
    Keen to know your favorite endmills you are using for alloy? I think for me something at 10mm with a decent bit of length would be nice. I am looking at spending around $100 so am keen to hear some advice or what works for you.
    I know all machines are different. Would be good all the same. Tell me which endmill you would shed a tear over if you crashed it into your vice jaws. B
    Sent from my SM-N970F using Tapatalk
    Aug 2020
    16
    Re: Which is your favorite end mill for Alloy?
    MZG 75
    Jul 2021
    8
    I have always bought something from aliexpress, including end mill for Alloy, several times more expensive than I could buy. As soon as I make a purchase, after a while I come across the same thing several times cheaper. Over time, it started to infuriate me,but it didn't last long because I found Alitools that helped me cope with it.
    Oct 2023
    7
    Hello, we are manufacturer of cbn insert from China.
    We can give you advice about how to choose insert.
    We also do endmills.
    Welcome to enquiry.
    Whatsapp: +86-18282557341
    E-mail: [email protected]
  1. Using fly cutter vs End mill end for flatten material
    By Micro Milling in forum MetalWork Discussion
    Last Post: 04-01-2010, 01:07 AM
  2. How to mill out a large window in the middle of an alluminum alloy structure?
    By diemetric in forum Uncategorised MetalWorking Machines
    Last Post: 01-07-2010, 04:25 PM
  3. Running carbide end mills in side-lock end mill holders
    By Cory in forum MetalWork Discussion
    Last Post: 01-14-2008, 02:55 PM
