586,036 active members*
3,552 visitors online*
Login Register
Siemens Digital Industries Software Forum
Where today meets tomorrow.
Fanuc > Enshu VMC400 Fanuc 6M B 4th axis it4 interlock signal locating
Results 1 to 3 of 3
    Oct 2021
    We're upgrading an enshu VMC 400 to 4 axis and have gotten as far as the 4th axis fanuc servo powers up and is held from rotating by the controller, however we can't move it in either direction with C axis switch. It can not be rotated by hand in either direction when the machine is turned on.
    Does anyone know where/how to switch the it4 interlock signal, according to a Russian manual of this controller there's a connector named C03 in which #36 is supposed to enable/disable 4th axis interlock?
    thanks
    Please see video
    https://fb.watch/8MDvRZOzLF/
    Aug 2019
    145
    Re: Enshu VMC400 Fanuc 6M B 4th axis it4 interlock signal locating
    The 4th axis interlock is actually on C01. So if you see something referencing C03 the control may have the PMC feature which means you need the prints or ladder to determine where the signals would get connected.
    I'm guessing what it is looking for is "4th axis unclamp confirmation"
    C03 pin 36 is 3rd (Z) axis interlock with no PLC. So this also points to the control probably having a PLC
    Oct 2021
    Quote Originally Posted by oetkbyentc View Post
    Actually it turned out to be on C02, we solved it and now the 4th axis works. It seems Enshu reconfigured pins as they felt like.
    Video of 4th axis working:
    https://fb.watch/8NVZJTMpN5/
  1. 2000 axis interlock alarm fanuc om
    By Braided1122 in forum CNC Machining Centres
    Last Post: 05-16-2022, 03:08 PM
  2. Fanuc OM AXIS INTERLOCK
    By RoblesTig275 in forum Fanuc
    Last Post: 05-09-2022, 08:02 PM
  3. Parameters enshu vmc 330 4th axis fanuc 10M
    By JEISON in forum Questions or Problems
    Last Post: 06-06-2019, 11:14 PM
  4. Mori Seiki MV-40 4th axis interlock.
    By GPena in forum Mori Seiki Mills
    Last Post: 08-20-2014, 03:04 PM
  5. Replies: 0
    Last Post: 11-22-2011, 04:51 PM
