Where can I get ( or is there) a small CNC 12" x 24" machine with Accuracy of +/- .001 for under $3000.00
Where today meets tomorrow.
Accuracy is a function of setup and machine rigidity. It also depends on what you are cutting. Resolution and repeatability are really the most important, and almost any CNC machine today has more than enough resolution to do what you want. Most will repeat just fine also.
So if you are cutting wood, then almost any of the table top machines should be able to achieve the accuracy that you desire. If you are wanting to cut aluminum or steel, then maybe you need to look for a heavier machine.
Jim Dawson
Sandy, Oregon, USA
I was looking at the Shark but +/- .005 not going to cut it
These are a simple pattern I made to make a Riser for a Recurve bow
A .005 gap will be visible
I like this----5 axis cnc LFG6090 Intechcnc small cnc milling machine //aluminium cnc
Jinan Intech Mechanical Equipment Co., Ltd.
I don't know what other software will work but one they recommended was $1000.00
https://www.aliexpress.com/item/32456872389.html
They must be using some kind of new math to calculate the number of axes, I only count 3, not 5. I see a number of other mistakes in their ad also.
Mechanically the machine is probably OK, but who knows about the electronics and controller. They say it works with G code, so most likely would work with any CAM program that would generate a Mach3 post, pretty generic and common. CAD/CAM software prices run from free to ''you can't afford it''. The hobby version of Fusion 360 is still free, although somewhat broken from what is used to be.
Jim Dawson
Sandy, Oregon, USA
