586,069 active members*
3,484 visitors online*
Login Register
Siemens Digital Industries Software Forum
Where today meets tomorrow.
Controller & Computer Solutions > Adtech CNC 4620 2 axis lathe tutorial?
Results 1 to 2 of 2
    Oct 2019
    4
    I have a little baby Xendoll 2 axis lathe, which I'd like to use for simple tubing and mandrel parts. I'm a mill guy, so I've got some learning curve. The control is an Adtech CNC 4620; the manuals aren't particularly intuitive, and it's often hard to tell which button it's referring to. Is there a tutorial anywhere for how to perform basic functions on this control, including specific button pushes?
    Thanks!
    -Matt
    Sep 2011
    23
    Re: Adtech CNC 4620 2 axis lathe tutorial?
    I have an Adtech 4620 on an Ecoca lathe. Yes, the documentation is bad. As far as I can tell that's all there is. Mine is working but its not a controller that I would recommend to others. It doesn't have tool nose radius compensation and I haven't been able to make it home to the "Z" encoder signal. It homes to a mechanical switch which isn't accurate enough to be useful.
    If you have specific questions I may be able to help.
